Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 01-02-2009, 09:52 PM
agoodhi agoodhi is offline
Exclamation Leak from under the dash
It seems there is some type of slow oil (?) leak coming from the brake pedal piston area. Anyone have any idea on how to remedy this?
--Ryan
Old 01-02-2009, 09:53 PM
cchase cchase is offline
sounds to me like the orings on your CCV are leaking, its a little rectanlge on top of the driveside valve cover. I would start there
-Edit- Did I complety read that wrong, or did you change the wording?
Old 01-02-2009, 10:00 PM
alberta 7.3 alberta 7.3 is offline
<- Insert Dana 60 here!
Sound like the hydroboost unit leaking, may have to replace with a reman'd unit.
Old 01-03-2009, 03:22 PM
dmd dmd is offline
No idea how that would get in the cab...
Yep, hydroboost or
master cylinder. Have to remove the both so you will find the
issue when you are there.
Old 01-07-2009, 07:00 PM
240 spoke 240 spoke is offline
Mine was leaking also...You stand on your head under the dash and follow the push rod from the brake pedal towards the fire wall and you will see the oil leaking around the shaft...Do you get oil drops on your foot or is it leaking to the carpet...See me Matt
Old 01-07-2009, 10:29 PM
I haven't had time to spend on this yet...
It seems there was a leak at one point because there is evidence of an old spill on the carpet with the leak orginating from the firewall (I'm guessing the PO fixed it, not sure what it was though).
The leak I recently spotted seems different, but I need to look again to make sure.
Old 01-07-2009, 10:54 PM
symbols symbols is offline
Nonsense specialist
Mine is leaking as well. Havn't replaced it cause it's more like seepage right now
Old 01-10-2009, 11:33 PM
You described my exact leak!!! Mine just goes down the firewall.
How do you fix it?
Old 01-17-2009, 05:31 PM
Devin Devin is offline
Heres another post describing fixing the hydraboost:
Hydraboost leak
near the bottom
Old 01-18-2009, 10:12 AM
Thanks for the link Devin. Hopefully it'll get me going in the right direction.
I'm wondering if it is critical to fix ASAP. Mine is just a slow seepage.
