99 F350 reving issue - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-27-2014, 03:52 PM Thread Starter
gmat's Avatar
I have a '99.5 F350 CCLB 4x4 with 160k miles. I've only had the truck about 6 months and it didn't have this problem when I got it but I don't remember exactly when the problem started happening. But anytime I turn the truck on and it's cold the check engine light will come on. After about 20-30 seconds the light will shut off and the RPM's will jump about 200 or so. The RPM's jumping and check engine light going off happen simultaneously. If I drive the truck for a while, turn it off and then turn it back on before the engine cools to much this doesn't happen, only when it's a cold start. Does anyone know what this could be?
1999 F350 4x4 Crew Cab Long bed. 240k miles and bone stock as of now. Looking to change that soon
gmat is offline
post #2 of 6 Old 05-27-2014, 04:42 PM
Vannnce's Avatar
Quoted: 13 Post(s)
have you pulled codes?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 6 Old 05-27-2014, 04:52 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Do you have the latest and greatest cps? That'd be my first guess.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 6 Old 05-27-2014, 05:00 PM Thread Starter
gmat's Avatar
I haven't had a chance to pull codes yet.
And what do you mean by cps?
gmat is offline
post #5 of 6 Old 05-27-2014, 05:21 PM
LoxDiesel's Avatar
Quoted: 350 Post(s)
Crank Position Sensor. About 20$ from Ford
@loxdce
post #6 of 6 Old 05-27-2014, 05:28 PM
Vannnce's Avatar
Quoted: 13 Post(s)
beings as theres been a check engine light, id start off by pulling codes. for what its worth, its always good to have a CPS in the glove box
-Vance-
I.B.E.W. Local 1002
Vannnce is offline
