Clutch piece broke and flew apart? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-22-2014, 03:28 PM Thread Starter
On my way home from work today, my clutch pedal flew apart. My brother was able to fix it enough to where I could start it, and not use the clutch driving home. I believe I found the culprit of the problem. I can't really describe it any better. There is a metal piece that flew out and made the clutch pedal go to the floor.
Now the clutch pedal sits up real high, past the brake pedal.
2000 F350 "Red" - 2" Level - 18" Pro Comp Wheels - 35x12.50 Federal Couragia's - Superchip
(Looking to buy a Ts, if you got a deal) - Recon Cab Lights - Offbrand Harley Lookalike Headlights
Tommy7.3 is offline
post #2 of 2 Old 05-26-2014, 07:12 AM Thread Starter
After driving the truck another 300 miles, not using the clutch. I figured out the problem. It was my master cylinder. It was not grabbing the clutch push arm and holding it. So when I let off the clutch, it was coming out of the cylinder. That wore out the bushing where the rod connects to the clutch pedal. Causing it to fall off, along with the clutch position sensor. Which is bad by the way.
So where could I go about getting a clutch position sensor? I'd almost bet that's why my cruise control isn't working.. still..
Tommy7.3 is offline
