First start needs a jump - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-19-2014, 03:18 AM Thread Starter
Had this problem back a couple months ago. I replaced both batteries, both ground cables, GPR, CPS. Problem went away. Now it's back again. Had batteries load tested,and alt. tested. Alt was charging 14.2 volts, with 62 amps. What next? Any ideas? Starts up perfect with a jump, then starts fine the rest of the day. ???????
Outagas is offline
post #2 of 6 Old 05-19-2014, 05:44 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Disconnect your battery's when you park it for the night then reconnect them in the morning and see if it will start. If it does start you have a parasitic draw. Also you can try to pull your battery's when you park it and have them tested the next day and see if letting them sit for a while will make difference in the load test.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 6 Old 05-19-2014, 06:03 AM
Jeff-F350's Avatar
Quoted: 14 Post(s)
X2.
Are you sure they did a load test on the alternator? 62 amps is what was being drawn, or what it is capable of producing? If that is its max capacity under load test, I would say the alt is on its way out.
~ Support them
2010 F350 CCSB SRW
Cabela's edition
2004 F350 SCSB SRW
Deleted
Sinister Coolant Filter
Everything else stock.
Original head bolts
1996 F250 RCLB
Plow Truck
Jeff-F350 is offline
post #4 of 6 Old 05-19-2014, 09:09 AM
I had this problem last week. the jumper cable that connects the positive terminals on the batteries was pretty badly corroded. replaced it and sprayed everything with corrosion preventative, no problems.
dieselup89 is offline
post #5 of 6 Old 05-20-2014, 04:52 PM Thread Starter
Fixed it, positive battery cable... Should have replaced it a couple months back when I changed ground cables..thanks for input fellas.
Outagas is offline
post #6 of 6 Old 05-20-2014, 09:22 PM
blue99stroker's Avatar
Quoted: 246 Post(s)
lol i was going to say positive cables when i read the first post. but looks like you got it fixed.
the positive cables are the ones that get corroded bad.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
