still low boost after boot leaks fixed - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-17-2014, 10:26 AM Thread Starter
Zen
ok, I did a boost leak test and fixed all the leaking boots. I still am only getting 17 at WOT with the red tube disconnected and plugged. I don't see any dusting from up pipes, but honestly don't know exactly what dusting looks like.
What are other sources of low boost other than
boots
turbo wheel
up pipes?
Waste gate seems tight, although I guess I could wire it shut as a test
I don't want to pull the turbo just to inspect it and don't want to throw up pipe parts at it right now if I don't need to.
Boost did go up a couple of PSI after fixing boot leaks.
Or is 17 normal? I thought 20-25 especially with red tube mod.
Thanks
Zen is offline
post #2 of 12 Old 05-17-2014, 12:11 PM
Quoted: 28 Post(s)
tuned or stock? up pipes will have soot streaks more than likely where they connect to back of turbo. the firewalls may also have some soot on them too. leaking manifolds is another source of boost lost. how many miles are on your truck?
http://i117.photobucket.com/albums/o...haust_Leak.jpg
that's what it will typically look like.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 12 Old 05-18-2014, 05:19 AM Thread Starter
Zen
Only mods red tube egrv disconnected, straight pipe.
215k miles
Will look for streaks today
Would the up pipes up during a boost leak test?
Are you talking exhaust manifolds or intake manifolds?
Thanks
Zen is offline
post #4 of 12 Old 05-18-2014, 06:24 AM Thread Starter
Zen
Drivers side up pipe is definitely leaking so time to order parts. Could a leaking up pipe make a ticking sound like an exhaust leak as well? Any other mods I should do while I have the up pipes out or things I should check?
Thanks
Zen is offline
post #5 of 12 Old 05-18-2014, 10:32 AM
Quoted: 28 Post(s)
You mean red tube for wastegate. You don't have an EGR on a 7.3. Up pipes wont show up on boost leak test. Exhaust manifolds NOT intake. Resurfacing them and using new gasket and bolts will fix them if they're leaking.
A leaking up pipe will make a ticking sound like an exhaust leak because it is an exhaust leak. Replace them with international bellowed up pipes. I got mine from Riff Raff Diesel. Go ahead and order the turbo pedestal orings (upper and lower) since you'll have the turbo off. If you want to now would be the perfect time to delete the EBPV and either mod your current pedestal or order the non EBPV pedestal for 115 bucks. I wish I had done this when I did up pipes. If you want to keep the EBPV order the EBPV pedestal rebuild kit. Pedestal orings and EBPV are two very common places for oil leaks on 7.3's.
-Kris
4'' straight pipe
DIY 6637
38r
The Following User Says Thank You to strokin-7.3 For This Useful Post:
Zen (05-25-2014)
post #6 of 12 Old 05-25-2014, 04:12 PM Thread Starter
Zen
ok, up pipes replaced and EBPV deleted. Still only getting about 18 of boost pulling a trailer at WOT. Since the EBPV has been deleted do I need to worry about the EBP sensor and tube as far as creating a lower boost condition? Any other thoughts? How do I test the waste gate?
Thanks
Zen is offline
post #7 of 12 Old 05-26-2014, 07:41 AM
Quoted: 28 Post(s)
EBPV delete wont affect the EBP sensor and tube, just make sure the tube is free from soot obstruction and the sensor isn't plugged with soot. You could wire the wastegate shut to be sure it isn't opening. What I would do though is hook your red line back up to wastegate and see what kind of boost you're getting. 15-17 on stock is normal.
EDIT: How's the turbo wheel look?
-Kris
4'' straight pipe
DIY 6637
38r
post #8 of 12 Old 05-26-2014, 09:05 AM Thread Starter
Zen
turbo wheel looked good on both sides with no play.
Zen is offline
post #9 of 12 Old 05-27-2014, 04:46 PM Thread Starter
Zen
ok the EBP tube and sensor were totally plugged and the tube was broken. Boost is now up to 19max at wot. I can't test putting the red tube back on as the vacuum boot disintegrated when I took it off. Would bad vacuum seals around the red and green tubes cause any issues? they are all shot and need to be replaced. Anybody have a part number for the rubber boots?
Zen is offline
post #10 of 12 Old 05-27-2014, 05:47 PM
Quoted: 28 Post(s)
Did you put a cap on the red line since the boot dry rotted? I believe the green line that runs to the intake tubing is just the excessive boost pressure that is bled off by the wastegate. So it won't affect boost. However the red lines are pressurized anytime you're making boost so dry rotted boots could have an effect on boost pressures. Sorry, I have no idea on the part numbers though.
-Kris
4'' straight pipe
DIY 6637
38r
