Keep Blowing #3 fuse - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-15-2014, 04:53 PM Thread Starter
Driving the other day I noticed that my scan gauge was working. Thought maybe the scan gauge died so I tried it on another vehicle and it worked. So I figured my OBD 2 port was not working. I looked up why it wouldn't work, everybody said to check the #3 fuse. I did and it was blown, I replaced it, connected the batteries and it blew again. I'm not sure what the problem is. Any help would be greatly appreciated.
2001 f250 cc sb, Zf6 swap with zoom 650 horsepower clutch, Ts six position chip, Banks 4" turbo back exhaust, Ats ported compressor housing, riffraff high flow compressor wheel, riffraff boost fooler, 10 inch lift on 40 inch procomps xtreme terrains, RiffRaff FRx, Airraid cold air intake, boost and egt gauges.
Mario_SD is offline
post #2 of 6 Old 05-16-2014, 01:29 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
In your owners manual, what does it say the fuse that's blowing is protecting?
#3 doesn't make sense to me, be sure you're looking at the right number....
NoRalPh is offline
post #3 of 6 Old 05-16-2014, 01:40 PM Thread Starter
It says it's the obd2 and cigarette lighter. I don't know if this helps but the problem started after I had to change the shifter bar that runs along the steering column. I had to take out the key tumbler and the shroud over the steering column. But yes it's the #3 fuse. Thanks for your reply.
Mario_SD is offline
post #4 of 6 Old 05-16-2014, 05:24 PM
Quoted: 143 Post(s)
See, on a '01 it's hard to know which fuse panel you have. My '02 says "Empty" for #3. There was a major electrical change during the '01 run...
One of the power supplys to the PCM is shared with the OBD port so if it's blown you don't have a running PCM and it's Never gonna start (you don't have a WTS light I assume?)
Could the outlet be shorted (you know, one of the kids put a dime in it )
I don't know if it could be related to the key tumbler, did it go back easily? Maybe take the column covers off again and look around for a wire problem, take the ign cyl out and look at that too.
NoRalPh is offline
post #5 of 6 Old 05-16-2014, 05:42 PM Thread Starter
I guess I have the fuse panel you dont have. But I do have a WTS light and the truck runs and drives perfect. Both cigarette lighters are clear. Everything went back together fine except for the connector that sits in where the tumbler goes. From everything I've read this has me stumped.
Mario_SD is offline
post #6 of 6 Old 05-16-2014, 05:51 PM
heykw's Avatar
I vaguely remember hearing something about a short in the column
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
