Help finding source of oil leak - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-12-2014, 01:17 PM Thread Starter
Tempsho's Avatar
Quoted: 3 Post(s)
I have an oil leak and I am not too sure where its coming from. My valley is bone dry, and the high pressure oil plug at the back of the engine is dry as well. Where else could this leak be coming from? I hope the pictures help.
2002 7.3L Excursion Limited 4x4
- 21"/11"/21" Vision X Xmitter Prime light bars (47,000 lumens)
- Edge CS Monitor
- Tymar intake
- Fumoto Quick Drain Valve
- Coolant filter, ELC, 203* T-stat and billet housing
- Riff Raff boots
- PHP Chip (Stock, 80DD, 100Race, Whisper Mode, 80Tow, Smoke Show)
- F350 leafs front and back
- Hellwig rear sway bar, Bilstein 5100's
- LT275/65R20 Durtrac's on 20" King Ranch wheels
- Fred Goeske 2" steel wheel adapters
- Genuine Larry B's Denso starter
Tempsho is offline
post #2 of 2 Old 05-13-2014, 08:03 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Make a paper towel "Kotex" and slide it under the turbo pedestal maybe....
Run the engine and slide it out after a min or two, see if either side is wet. If not, drive it around some and check again.
Also, here's an interesting video, BUT I have to warn you about this guy,,,, he makes Great Videos, that Does NOT make him infallible. He's got some really GOOFY theories (not about this though) So, don't take him as your Guru, as many do Confirm his advice on anything else he says
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
NoRalPh is offline
