Eating starters after one start? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-06-2014, 08:07 PM Thread Starter
Quoted: 2 Post(s)
alright I have searched the whole web for a solution and haven't found one. About 2 weeks ago my batteries weren't getting charged so I replaced alternator and both batteries, truck started up. Go to start again and nothing, only noise was the fender mounted solenoid clicking over. I replaced the starter along with positive battery cables. Ran for one start and same problem, solenoid clicking but the flywheel not kicking out. Brings me to today, replaced the negative battery terminals and a new starter. Started once and then it wouldn't start again. Every starter has been tested and failed for the flywheel not kicking out. What could be causing this? I am stumped...
By the way this is an E99 f250 SD 4x4
firefter31 is offline
post #2 of 11 Old 05-06-2014, 08:24 PM
ZMANN's Avatar
Quoted: 1335 Post(s)
the starter mounted bendex kicks out the starter gear that engages the flywheel
so your having bendex issues just not sure what you could be doing to them to fry em ?
We Miss you Ronnie
ZMANN is offline
post #3 of 11 Old 05-06-2014, 08:26 PM Thread Starter
Quoted: 2 Post(s)
I would say that's accurate ZMANN. Completely stumped
post #4 of 11 Old 05-06-2014, 08:35 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Is your key getting stuck in the start position? Maybe try rolling the key back after starting.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 11 Old 05-06-2014, 08:37 PM Thread Starter
Quoted: 2 Post(s)
It is not getting stuck. After I turned it off and tried it again I took the keys out ignition every time
post #6 of 11 Old 05-06-2014, 08:39 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
How long does it run before you turn it off and try to start it again. Do you have power to the signal wire on the starter after it is running.
01 f-250, Standard
sbluke55 is offline
post #7 of 11 Old 05-06-2014, 08:43 PM Thread Starter
Quoted: 2 Post(s)
normally from where it broke down to my house haha. But normally 10-20 minutes. I just was thinking, the first starter that went bad would spin but the flywheel wouldn't engage which means the bendix was for sure bad. But these ones don't spin after the first fire up
post #8 of 11 Old 05-06-2014, 08:49 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
After you start it go and check to see if you have power to the little wire on the starter. If have power your starter is turning the whole time the truck is running and after 10 minutes it burns up.
01 f-250, Standard
sbluke55 is offline
post #9 of 11 Old 05-06-2014, 08:51 PM Thread Starter
Quoted: 2 Post(s)
That'd make sense. What could be causing that?
post #10 of 11 Old 05-06-2014, 08:58 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Starter relay sticking on or your key is sticking forword in the start position after starting and not returning to run.
01 f-250, Standard
sbluke55 is offline
