Transmission leak help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-05-2014, 09:11 AM Thread Starter
Warrior449's Avatar
Exclamation Transmission leak help
Leak coming from on top of trans,was wondering if there is a seal between the spacer that separates the trans from the t-case or if it is just a dust seal,
Warrior449 is offline
post #2 of 2 Old 05-05-2014, 01:36 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
there is a seal between them.
sometimes if the seal fails the transfer case will get really full of atf.
you can drain the transfer case and if more than 2 quarts comes out the seal is bad. if not you just put 2 new quarts in. pretty quick and easy.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
