IPR or HPOP? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 28 Old 05-04-2014, 06:16 PM Thread Starter
Trfytow's Avatar
IPR or HPOP?
I have a crank no start situation, hpop putting out 470-530psi while cranking and IPR at 14.7% duty cycle with ignition on and while cranking, no movement. Thanks in advance!
Trfytow is offline
post #2 of 28 Old 05-09-2014, 08:58 PM
heykw's Avatar
How many miles are on the truck?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 28 Old 05-09-2014, 09:57 PM
Quoted: 818 Post(s)
Does your tach move while cranking? If not check fuse #22 or #30 IIRC.
Corey@CNCFAB is offline
post #4 of 28 Old 05-10-2014, 06:27 AM
Vannnce's Avatar
Quoted: 13 Post(s)
what year is the truck? In 02 and up dont they get there signal for the tach elsewhere?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 28 Old 05-10-2014, 06:49 AM
Quoted: 818 Post(s)
He's got a L99 that's why I ask
The Following User Says Thank You to Corey@CNCFAB For This Useful Post:
Trfytow (05-10-2014)
post #6 of 28 Old 05-10-2014, 06:56 AM
Vannnce's Avatar
Quoted: 13 Post(s)
i figured ya knew more than me, right on(:
-Vance-
I.B.E.W. Local 1002
Vannnce is offline
post #7 of 28 Old 05-10-2014, 07:59 PM Thread Starter
Trfytow's Avatar
Tach moves, fuse is good, new cps, new fuel pump, rebuilt fuel bowl, hutch and harpoon mod done on tank, DP F16 chip, ww2, bellowed up piped, rifraff boost fooler, wastegate controller.
Only thing I haven't replaced is the IPR. The ICP senson has no oil in connector and no check engine or SES light. I have the Torque app to diagnosis.
Trfytow is offline
post #8 of 28 Old 05-10-2014, 08:01 PM Thread Starter
Trfytow's Avatar
Wait to start light works normally also. No smoke when cranking and batteries 1 year old and fully charged.
Trfytow is offline
post #9 of 28 Old 05-11-2014, 09:12 AM Thread Starter
Trfytow's Avatar
One more thing, always have weird startup/random shutoff issues when parked uphill.
Trfytow is offline
post #10 of 28 Old 05-19-2014, 06:04 PM Thread Starter
Trfytow's Avatar
I took the IPR out and cleaned it up, put it back in and filled the hpop. It started first crank and idled perfect. Put in drive and touched the throttle and died. Started back up and put in reverse and runs perfect, back in drive and dies. Now won't restart.
Sprayed starting flud and it fired. So its definitely not getting fuel. Any thoughts?
Trfytow is offline
