Sudden drop to 12 mpg - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-16-2014, 06:00 AM Thread Starter
jdereu's Avatar
Help me out guys all of a sudden my truck mpg dropped to 12. I dont beat on it at all probably half city half highway. Replaced my intercooler boots a while back. Kt performance chip, 4" exhaust and 6637 intake. New cps, ICP and IPR. Boost about 19psi and Im in New mExico so my elevation is about 5000ft.
What else can I check?
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 12 Old 04-16-2014, 06:32 AM
timmyboy76's Avatar
clean/replace the EBP tube and sensor...located in front of hpop, to the left. Tube runs from there to front of p/s manifold
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 12 Old 04-16-2014, 06:32 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Maybe it has nothing to do with the engine...
Be sure your rolling resistance isn't the problem. A dragging caliper, low tire pressure, Ft axle engaged, that kind of stuff can have an effect.
NoRalPh is offline
post #4 of 12 Old 04-16-2014, 06:50 AM Thread Starter
jdereu's Avatar
I have only clean the one that runs from the passagener manifold to the center front of the engine. Ill have to look for the other one. Is it pretty easy to spot?
jdereu is offline
post #5 of 12 Old 04-16-2014, 06:55 AM
timmyboy76's Avatar
ya, thats the one im referring to.
post #6 of 12 Old 04-16-2014, 07:00 AM Thread Starter
jdereu's Avatar
Ya I cleaned that one never really clogged or anything to bad. Maybe that sensor is on its way out?
jdereu is offline
post #7 of 12 Old 04-16-2014, 07:31 AM
Quoted: 184 Post(s)
Are you hearing a hiss from that tailpipe once the engine is warmed-up (indicating the EBPV is restricting exhaust flow)?
What else would make you think this is a EBP issue?
NoRalPh is offline
post #8 of 12 Old 04-16-2014, 07:37 AM Thread Starter
jdereu's Avatar
My ebpv is gutted and remove. I dont think its a EBP issue really. Just taking suggestions
jdereu is offline
post #9 of 12 Old 04-16-2014, 07:59 AM
Quoted: 890 Post(s)
Have you changed your fuel filter lately?
Or a bit more exhaust smoke?
Look for (intercooler coupling) boost leaks and look for exhaust up pipe leaks.
Corey@CNCFAB is offline
post #10 of 12 Old 04-16-2014, 10:14 AM Thread Starter
jdereu's Avatar
Fuel filter recent yes.
More smoke yes.
How do I check for up pipe leaks
jdereu is offline
