Truck shakes in warmer weather, fine in cold weather - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-15-2014, 02:11 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
As the weather is warming up I have noticed that the truck idles rough and shakes in lower rpm. Whether the truck is warm or cold it does not seem to matter, however when the ambient temp is colder (below 40) the truck does not seem to have any issues, all is normal. But above 40 it starts to develop a shake between idle and 1200 rpm. If it is above 60 degrees it has a very rough idle and shakes up to about 1500 rpm. I still plug in my truck at night and have no issues on the 30 minute drive to work at 6am when it's cool out. But on lunch break and after work when it's warmer the truck shakes and intensifies with the outdoor temp. It gets to almost 100 here in the summer so I need to fix this soon
*Bought March 2011 @ 150K / Sold March 2016 @ 230K* E1999 7.3 PS 6 Speed,TS 6 position chip. K&N CAI, 4" straightpipe, Auto Meter Elite gauges.
*Bought May 2016 @ 59K* 07 F250 HD Edition 6.0 Stock
shordinges is offline
post #2 of 5 Old 04-15-2014, 02:15 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
Also I spend the weekends in a different area that is about 10-15 degreese warmer than my home, when I am there the truck will shake really bad in the morning because it's warmer there so I know it's not an issue about sitting overnight and cooling down.
post #3 of 5 Old 04-15-2014, 09:00 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
sounds fuel or oil related.
how long since you changed the oil?
i had a shake at idle before as well, i rebuilt the Fuel pressure regulator and it helped some.
i the replaced the icp and that helped more.
also i run synthetic oil and the truck runs smoother.
on a random note you can try a different cps.
i recommend the delphi hts101. little smoother starts and idle over the ford grey cps.
why do you need to plug your truck in? mine starts fine in the teens unplugged.
any codes?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 5 Old 04-16-2014, 11:14 AM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
I plug in my truck still so it's warm in the morning and doesn't need as much warm up time. I leave my apartment at 5:30 am and my neighbors don't care for a straight piped powerstroke running that early, it's a courtesy to them really.
I changed my oil about 3k miles ago with the usual schaefers full synthetic like always. Oil sample was good. But it was colder then so the issue might have been present but not noticeable until the weather changed. I have all original sensors
post #5 of 5 Old 04-16-2014, 06:11 PM Thread Starter
shordinges's Avatar
Quoted: 14 Post(s)
Garage
And no codes, but it's possible my chip might clear codes that it thinks it should ignore, I'm not sure if it's capable of that
