7.3 clunk when accelerating from stop - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-11-2014, 01:40 PM Thread Starter
coolBlue02's Avatar
Quoted: 3 Post(s)
Automatic 2002 7.3 f350 here. When accelerating from a stop something in the drive train likes to clunk. I was gonna say stutter but that's a little misleading, its not like the trucks revving freely and then slamming into gear. It also happens when I'm braking into a complete stop. I was in some stop and go traffic today and had plenty of time to let it bug me. The clunk happens between 0-5mph. It doesn't seem to affect drivability just want to put a finger on what it may be. Torque converter? Driveshaft u joints? Typical 7.3 behavior? Thanks dudes
coolBlue02 is offline
post #2 of 8 Old 04-11-2014, 03:50 PM
Vannnce's Avatar
Quoted: 13 Post(s)
sounds like my problem. mine doesnt do it if i pull the rear shaft. tomorrow i will be replacing u joints and carrier bearing as they are shot
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 8 Old 04-13-2014, 08:32 PM
Probably just need to grease the drive shaft splines.
dmd5@mindspring.com is offline
post #4 of 8 Old 04-13-2014, 09:03 PM
yep grease the drive shaft spline. Worked for me
2001 F250 Crew Cab 4X4 Auto,Diamond Eye 4" Turbo back, 2.5" Mini Spring Kit, AIS intake, ZOODAD Mod, 6.0 Tranny Cooler, Cold A/C Mod.
chipw is offline
post #5 of 8 Old 04-13-2014, 09:06 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
There is a blue special plastic-like coating on the driveshaft splines that wears off after time, and a particular grease Ford sells that you can coat the splines with that remedies this, but you have to be careful and not use too much or you end up creating a "suction" lock on the shaft. I need to do mine...
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #6 of 8 Old 04-13-2014, 09:33 PM
Just had the same issue...it was the ujoint and carrier. It was so bad, it was almost embarassing
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #7 of 8 Old 04-13-2014, 11:44 PM
Rodslinger's B1TCH
PTFE lubricant. i've tried replacing it with other types of grease and nothing else lasts nearly as long on sliding parts
https://www.fcsdchemicalsandlubrican...tegory=Greases
steve604 is offline
post #8 of 8 Old 04-14-2014, 09:11 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
ya it is most likely the slip joint like everyone else says. just need a 7mm socket to get the driver shaft loose.
make sure you mark where you pulled it apart.
also sometimes the drag link clunks but this obviously isnt whats causing the clunk from the rear.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
