Front drive shaft u joints - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By duck fan
  • 1 Post By Harley516
post #1 of 4 Old 04-10-2014, 09:55 AM Thread Starter
Quick question looking for tips. Need to replace the ujoints for the first time off the transfer case. It looks like you can remove some bolts and the whole shaft comes out. Is this right or am I missing something? Cant complain getting 285k out of he originals! Thanks guys!
mkfan17 is offline
post #2 of 4 Old 04-10-2014, 10:33 AM
duck fan's Avatar
Yes, the shaft unbolts from the flange on the transfer case. I had both my shafts rebuilt at about 275K and they were overdue. 285K is a great life out of it.
mkfan17 likes this.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
The Following User Says Thank You to duck fan For This Useful Post:
mkfan17 (04-10-2014)
post #3 of 4 Old 04-10-2014, 11:37 AM
Harley516's Avatar
4 bolts by transfer case, 4 nuts on straps and the shaft is free..
8mm bolts on straps, 13mm bolts on other end.
my strap bolts were rotted so an 8mm would not fit, had to grind strap off and use a torch to heat up the bolts in order to back them out..Loads of fun!..
mkfan17 likes this.
Harley516 is offline
The Following User Says Thank You to Harley516 For This Useful Post:
post #4 of 4 Old 04-10-2014, 03:30 PM Thread Starter
Yea 285K is awesome, too bad the fronts don't last a quarter of that time!!
Thanks for the info guys!
mkfan17 is offline
