CCSB no interior lights, courtesy lights, ceiling custer, bed lights?! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-09-2014, 02:32 PM Thread Starter
Brian.'s Avatar
Like the title says 2001 CrewCab Short bed (lariat if it matters) doesn't have interior lights, bed lights, courtesy lights, or the little ceiling instrument panel lights??
I put in a 20A fuse (there wasn't one in there when I bought this truck) and it blew it instantly. I checked all the wires that are in the rubber grommets, as I've read it will wear on the wires eventually. But they all checked out good. Any idea's?
2001
F250 CCSB Lariat GTP35R-4"turboback TS 6pos.
2004 Dodge Neon SRT4 stage III turbo, injectors, ECU, exhaust. AGP BOV, AGP wastegate, Big turbo, Large FMIC
2001 BMW 325i-lowered
1988 BMW 535i laying frame, 2.5" straight pipe.
Brian. is offline
post #2 of 5 Old 04-09-2014, 02:42 PM
Quoted: 5 Post(s)
I had the same problem a month ago and it was a bad battery connection at the passenger side battery. I checked all fuses and they were good. My guage cluster was doing some wierd things also. hope this helps.
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #3 of 5 Old 04-09-2014, 02:44 PM Thread Starter
Brian.'s Avatar
My gauge cluster works fine, MINUS the tach. It works sporadically. I'll give that a try! I just bought the truck not too long ago, so I'm still getting the small things fixed.
2001
Brian. is offline
post #4 of 5 Old 04-11-2014, 04:36 PM Thread Starter
Brian.'s Avatar
Bumping this, still having an issue.
2001
Brian. is offline
post #5 of 5 Old 04-11-2014, 04:37 PM Thread Starter
Brian.'s Avatar
My tach also rarely works, an when it does it only works for a short short time.
2001
Brian. is offline
