Truck stalls out intermittently - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-08-2006, 01:48 PM Thread Starter
Question Truck stalls out intermittently
I have a 97 350, just recently the truck started running poorly I had a couple of cam codes. I replaced the cam sensor agian, still had a problem. I still had a p0344 intermittent code so I tore apart the harness from the camshaft position sensor to the pcm, ohmed everything out found nothing. My fuel filter was plugged up pretty badly, I went to replace it and found the fuel filter housing was pittted, so I replaced the entire assembly. I thought I was in the clear, I was wrong. I started it up it ran fine for ten minutes and then started running rough then it died. It would not restart for about 15-20 minutes. I got it started again and drove it hard for about 15 miles, put new fuel in, when i went to slow down at a light it started running rough again wanted to stall, it did that twice. I scanned it again and there was the p0344again, the only thing I can find is that the electrical connector for the cmp is a little wourn out. I went to get one but they only sell it in the whole harness(120 my cost). Its either the pcm or connector or I have a bad pin in the main injector harness connector. Does anyone know where I can get just the cmp connector pigtail, or have any insight on my problem.
Thanks
X-FORDTECH is offline
post #2 of 3 Old 12-08-2006, 02:36 PM
duct tape & zip ties
bigcountrysg's Avatar
Have you checked around junkyards. That is where I would go. You might be able to find a 97 F-350 at a junkyard and beable to salvage the wiring harness out of it for a decent price. Obviously stay away from the burnt trucks.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 3 Old 12-08-2006, 02:41 PM
The Fat Mod
Logan's Avatar
To POWERSTROKE.ORG
Logan is offline
