starts then dies a few minutes later - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-05-2014, 02:50 PM Thread Starter
this problem just started about a week ago and happens every morning.
starts right up runs a bit rough then smooths out. take it out on the road about 1/4 mile it seems to be starving for fuel twice it has stalled but every other time it's like having no fuel. then it regains power and it's fine for the rest of the day?
99 f250 7.3 standard 92245.0 miles
thanks for the help
steve
ffsteve is offline
post #2 of 4 Old 04-05-2014, 07:20 PM
timmyboy76's Avatar
could start with the basics. How many miles on oil? Check hpop resivoir, see if oils 1/2-3/4in from plug. Change fuelfilter. May need to do the HUTCH mod
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 04-06-2014, 01:32 PM Thread Starter
oil was just changed about a month ago, just changed fuel filter ( haven't driven since changed)
what is hpop? , see if oils 1/2-3/4in from plug ( what plug?) , and what is a hutch mod?
ffsteve is offline
post #4 of 4 Old 04-06-2014, 03:13 PM
Googs's Avatar
HPOP is your high pressure oil pump, it's in front of the fuel bowl under the plastic powerstroke cover, there is a plug on top of the HPOP reservoir, take out the plug it should be 3/4'' down, you might have to use a cable tie as a dip stick.
2003 F250 4X4 CC 7.3, 4R100HD
4' Turbo back exhaust, Banks Power Elbow, LPG (Gas over Diesel), DP Tuner F6, RR 6637 intake, RiffRaff Frx, Hpx, filter, Custom made transmission cooler with twin thermo fans, water to oil cooler, ScanGuage 2, Auto Meter, trans, EGT, Fuel pressure, Water to oil temp, Boost, Longrange fuel tank, 15000 Lbs winch, ARB winch bar, ARB lockers Fr & Rr, lightforce spot lights, HID's.
Googs is offline
