Problems with throttle - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-31-2014, 12:15 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
weird thing about the truck i noticed, it was running hotter egts than normal yesterday for some reason. i know it was really windy, but normally i back into the driveway and it is normally cool enough to shut off(below 400) but yesterday it was still 475....feels like something is shuddering under loads like going up steeper hills (at high way speeds) and it feels a little underpowered. I am wondering if something is going on with the converter. at idle it will draw down the revs about 100 rpms and then pop back up to 600/650 for a minute, then draw down again to about 500/550....
What's this sound like to y'all?
Coming back from Rudy's truck jam last month, the truck was running fine all the way down the road. its a little over 3 hours over there from me. Drove great on all the way over never missed a beat. On the way back about maybe 40 miles from home it started this In and Out kind of no throttle response type thing. it would do it maybe once every 5 to 10 miles. And that's it. it never fully lost throttle response, my gauges never fluctuated my WTS light never came on, nothing like that. but it was just like I had all the sudden taken my foot off the throttle going down the interstate, when I actually hadnt moved my foot off the throttle. thought it might have been something with low fuel because I had about an eighth of a tank and maybe I have a cracked pickup tube or something so I pulled over and got fuel and it did it may be a couple more times going down the road right after I got fuel. So maybe there was air in the lines? But then all the sudden this shuddering things started and the higher egts thing happened. I haven't done a buzz test or anything like that. No codes are showing up, and I'm thinking that it might be something with my torque converter maybe? I have a built transmission with a warranty so I'm not worried about fixing it at all but I just don't want to leave me stranded somewhere. could it be in IDM problem? I have checked all my grounds battery terminals and the like, and nothing is loose.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 8 Old 03-31-2014, 05:38 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Bump....
Nick
"The Mistress"
post #3 of 8 Old 04-01-2014, 06:07 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
Originally Posted by HVAC SuperTech View Post
it was just like I had all the sudden taken my foot off the throttle going down the interstate, when I actually hadn't moved my foot off the throttle.
That would have me thinking about the TPS, it's not an uncommon failure and at the beginning, it's intermittent, happening only occasionally in particular percentages. You'd have to be monitoring it's value though and be lucky to catch it when it happens.
All the stuff in the first paragraph would be unrelated to it, maybe you have more than one issue?
NoRalPh is online now
post #4 of 8 Old 04-01-2014, 06:24 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
I will try the tps...that's what I was thinking anyhow...just wanted some more info to go on....
Nick
"The Mistress"
post #5 of 8 Old 04-09-2014, 04:56 AM
Well how did you make out?
Drbruno4 is offline
post #6 of 8 Old 04-09-2014, 06:38 AM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Well I put a new t_p_s sensor on it 1 that I had under warranty. And it seems to be okay, better possibly. But it shut off on me when I came to stop at the exit ramp coming off the interstate. It's almost like the torque converter is not unlocking all the way sometimes when I come to a stop....and it also seems that when I'm pulling a hill it wants to unlock and lock and maybe that's where my drop in power coming from....egts seem to go down just a little bit so maybe the throttle position sensor or pedal position sensor was partially to blame on the whole ordeal....I really need to get a scan tool and monitor the locking and unlocking of the torque converter to see if that's the actual issue....I hope to be getting my traction bars put back on this Saturday so I probably won't have time to mess with it too much
Nick
"The Mistress"
post #7 of 8 Old 04-10-2014, 05:37 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Bought a new cps from Ford...changed it to see if that helps with my hunting idle problem when the motor gets to operating temp...Will post up results tomorrow evening after I drive it
Nick
"The Mistress"
post #8 of 8 Old 04-12-2014, 05:26 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Ok, so idle doesn't hunt anymore....truck seems to come down to an idle very nicely now, and never wanted to cut off...I hope this fixed it
Nick
"The Mistress"
