7.3 Transmission Wiring Harness - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2014, 06:04 AM Thread Starter
I am trying to help a friend locate a wiring harness for a 99 7.3, truck is a 4x4 but not sure if that makes a difference. Does anyone know what all years will interchange and does it need to be from a 4x4 truck or can a 2wd harness work and the transfer case is separate harness?
Also if anyone has a spare or parts one they would part with let me know.
cory99 is offline
post #2 of 6 Old 03-27-2014, 06:53 AM Thread Starter
Also does anyone know if the harness would be the same from a Expedition, Excursion or F150 that has the 4R100?
cory99 is offline
post #3 of 6 Old 03-27-2014, 08:22 AM
700xxmaniac's Avatar
Is ur truck auto t-case or manual? And 99-03 7.3 with the same tranny and tcase will work. If the excursion is a 7.3 and has the same t-case it will work
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #4 of 6 Old 03-27-2014, 08:26 AM Thread Starter
Thanks I believe it is manual Tcase will have to ask him to verify. But basically only a wiring harness from a 7.3 will work and not a 2wd? I havent seen it but he thought the transfer case harness was separate from the transmission
cory99 is offline
post #5 of 6 Old 03-27-2014, 08:47 AM
If it's a manual t-case a 2wd will but then your 4x4 light won't work and if you have auto locking hubs they won't work either.
-skyjacker 6'' lift
-sct tune
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-53mph top speed
post #6 of 6 Old 03-27-2014, 09:19 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I wouldn't think the 02-03 harness will work, There is a lot more wiring around the tranny in those years.
OP stick with the 99-01.5 and get one from a 4x4, its all the same harness
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
