HELP-fuel leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-24-2014, 05:57 AM Thread Starter
HELP-fuel leak
So, I walked out this morning to a wet spot under my truck...hhmmm. Didn't smell any fuel but when I cranked the truck to warm up, liquid came pouring out and onto the ground. I moved the truck forward and swiped the ground with my fingers to smell....FUEL I had to have someone come pick me up for work so I didn't get to look too closely, but there seems to be a hole where the fuel is leaking from...Anyone have any advice for me? Here are some pics:
Hopefully someone comes in here and tells me it's a $50 fix....probably not though
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #2 of 5 Old 03-24-2014, 06:22 AM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
Well you know it's not coming from there - right?
Look up top, I bet you'll find fuel in the Valley and it's just running back from there.
In most cases, fuel leaks Are actually $50 fixes! The two common spots would be the Drain (plastic yellow thing behind the Fuel Bowl) has bad O-Rings and the steel fuel line on the Rear Pass Head has a metal "clip" that secures it to the head and chafes thru.
Climb up there and have a Look
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
gentimmy (03-24-2014)
post #3 of 5 Old 03-24-2014, 06:25 AM Thread Starter
Thanks for the quick response! I'll get deeper into it this afternoon. Are these parts easily available at say, an Autozone?
I mean honestly, I didn't know if it's not coming from there because that piece I took a picture of looked punctured. I didn't know if fuel was getting recycled somewhere it shouldn't be and was exiting via a puncture wound or what...
'03 CCSB
6637
4" Lift
35" Duratracs
gentimmy is offline
post #4 of 5 Old 03-24-2014, 06:32 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
My guess would be your fuel bowl drain($50 new or rebuild it for $5 from diesel orings) or passenger side fuel line has a hole in it from a clamp rubbing on it.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
post #5 of 5 Old 03-24-2014, 09:10 AM
You might also check to see if the fuel filter cover has popped up. I've had it happen. Over pressure? Dirty filter? I don't know. It also happened to me this morning...I just went back inside and called in.
wasted_tracy is offline
