Trucks a Dog pulling 5000 LB - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-23-2014, 06:37 PM Thread Starter
I pulled a 5000 lb load of snowmachines and trailer this weekend. I wasn't real impressed with my 7.3. It has a stock early 99 with exhaust and intake. No chip.
It was very evident the trailer was back their. Took much longer to get up to speed at my normal throttle position. More than I thought it should take.
Speed limits are 55 here and going up some of the hills I had the pedal to the floor to keep it at 55. Nothing real steep either. 100% throttle up hills and I only saw 15 PSI of boost. Normal EGT's. under 1100*
No boost leaks that I can find under the hood, only oil soaked boots from my CCV.
Is this normal? I know an early 99 can be a dog, but I thought it would do better than this. A Hydra chip is on my list...
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #2 of 11 Old 03-23-2014, 06:42 PM
jesilvas's Avatar
Quoted: 2 Post(s)
It's a 7.3 Slow, but keeps going.
What read diff does it have, auto or manual trans? What RPMs were you running at 55MPH?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 03-23-2014, 06:57 PM Thread Starter
Its an auto. I don't quite remember my RPM's. Obviously I had OD off and by the sound I would say I was 2000-2300 RPM. My new isspro trans temp gauge still hasn't ever moved above 100 so Im pretty sure it doesn't work.
I've never had any issues with my trans slipping or anything so I don't think that was any problem. only 85,000 miles.
peter379 is offline
post #4 of 11 Old 03-23-2014, 07:02 PM
Quoted: 27 Post(s)
I've had the same thing happen to me and searched many forums hoping to find something. Only thing I found that I know I hadn't check was fuel restrictions besides the filter. Dropped the tank last weekend to check the screens in the mixing chamber and they were almost plugged up. Haven't pulled a trailer yet to see if there's a difference. It feels likes it drives better but it could just be in my head IDK. If there's no change when I pull a trailer next I'll hook up a fuel pressure gauge to rule it out for sure.
strokin-7.3 is offline
post #5 of 11 Old 03-25-2014, 04:09 AM
Carolina444's Avatar
Sounds like you got something going on.. I have e99 and it wasn't that bad in stock tune.. I'd start checking the basics.. Do you have torque app?
Early 99 f250 cclb,244k, ccv, Tymar intake, 4" diamond eye, 5" tip, 140v IDM, php hydra, isspro's, riffraff boots & billet wheel, ebpv delete w/ high flow outlet.
P.I.S injectors coming soon
Carolina444 is offline
post #6 of 11 Old 03-25-2014, 05:57 AM
hansel's Avatar
Quoted: 95 Post(s)
This was what I was thinking, with a 99 model year truck I'm willing too guess that he has a fuel tank issue. My truck had almost 250K when I noticed that below a 1/4 tank the injectors really started getting louder, sure enough my fuel pick up boot was broken and both filters where almost plugged shut. After dropping the tank and cleaning and replacing the pick up the truck really woke back up, I haven't towed with it yet but I'm waiting too see if the fuel mileage will increase when towing.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is online now
post #7 of 11 Old 03-25-2014, 02:19 PM Thread Starter
Thanks for your input guys. I went out to change the fuel filter yesterday since I haven't changed it since I've owned the truck. Got it out, and turns a filter my dad has for his 96' 7.3 is different than for mine so I put the old one back in until I can get to anchorage and pick up a few of the correct ones.
Anyway, regarding the tank problems. I've been wanting to do Tank mods since I bought the truck. I hope to take the bed off this summer to sandblast and install a goose neck. That will be the time that I do tank mods instead of taking the tank off the frame.
I do not have torque app or any other reading system besides my ol' school ISSPRO's.
peter379 is offline
post #8 of 11 Old 03-26-2014, 02:03 AM
"I do not have torque app or any other reading system besides my ol' school ISSPRO's. "
Best $30 you spend right there!
2002 F350 CC Auto 2x4 SRW SB
jhobbs26 is offline
post #9 of 11 Old 03-26-2014, 02:41 AM
I agree.. I use a samsung tab3 w/ torque and gauge pro. Works nice
post #10 of 11 Old 04-01-2014, 06:33 PM
Quoted: 27 Post(s)
New suggestions- Check fuel pressure and let us know what you get. Check pressure with key on engine off, idle, and WOT. I installed a fuel pressure gauge and had low pressure. My problem ended up being the fuel pressure regulator was just old and tired.
