emergency - won't start, stuck in Truckee with baby! - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-22-2014, 07:00 PM Thread Starter
skkele's Avatar
intermittent no crank
Hey all,
So I drove about 220 miles miles with on stop 150 miles in. Now at final destination, truck has been sitting for 4 hours, go out to start it and it a won't go.
All lights come up, won't even turn over or try.
One of the relays? But which one?
Thanks for the help?
Bonus points if you're in Truckee!
Feel free to text or call. 831-295-2837
2002 F350 CC LB 4x4 Lariat
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #2 of 18 Old 03-22-2014, 08:27 PM Thread Starter
skkele's Avatar
So... I plugged in my Bluetooth obd, turned it over, and it fired up. Pretty random.
Could the obd port have anything to do with it?
Ran it up and down the street, turned it off and on a few times. Everything seems normal.
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #3 of 18 Old 03-23-2014, 04:26 AM
I will guess at bad battery post connection on positive or negative.
Lights will work but no power to crank engine. Then it by luck works. Check them battery connections
early 1999 F350 CC LB DRW Mark111 just bought/ php hydra, Tony's tunes, ISSPRO EV2
1996 F250 BTS Tymar, MBRP, Baby Swamps,Autometer
1996 F350 Mason dump plow truck
jasult is offline
post #4 of 18 Old 03-23-2014, 07:32 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
I'd be thinking the NSSW (Neutral Safety SW) or the starter has a bad "spot" in it.
If it happens again, Lift the shift selector Up, past P, or try N and see if that does it. If it does, check the linkage for slop because the Torx bolts have come lose above the brake pedal.
You can often "fix" a hung starter with a Hammer, by rapping on the motor itself to jiggle things...
The Headlight are a good indication of where the problem lies. See if they Dim when you try to crank it over. If they Don't, it has nothing to do with the batteries.
Oh, and there's No Chance it has Anything to do with the OBD-II port
NoRalPh is offline
post #5 of 18 Old 03-23-2014, 07:34 AM Thread Starter
skkele's Avatar
Yep, plenty of juice to power everything but no crank whatsoever. About to go try it after sitting all night.
Thanks adult!
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #6 of 18 Old 03-23-2014, 07:36 AM Thread Starter
skkele's Avatar
Didn't notice a dim in the headlights last night and I checked the neutral switch bolts last night cause the truck had done that to me before but she wouldn't start in N either. I'll check the starter today.
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #7 of 18 Old 03-23-2014, 11:00 AM Thread Starter
skkele's Avatar
Just pulled it on me again at the filling station... moved the shifter to neutral and it started up. Gonna triple check the neutral safety switch...
aFe Stage 2 Intake
ARE Bed Cap
Rack-It Truck Rack
skkele is offline
post #8 of 18 Old 03-24-2014, 05:37 AM
Solid98's Avatar
Quoted: 8 Post(s)
Is your shifter getting sloppy? Check out youtube for "loose shift rail". That will show you the two torx bolts NoRalPh was talking about.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #9 of 18 Old 03-27-2014, 12:45 PM
i second neutral safety switch. The original worked fine on my 2003 7.3 but the shifter got real stiff to move. So i replaced NSS with new one and I had the same intermittent problems as you. The new one was bad, replaced with another new one and all is fine.
ml0923 is offline
post #10 of 18 Old 03-27-2014, 06:57 PM
timmyboy76's Avatar
starter relay im think'n. check the volts on output lug
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
