I've got a transmission problem.. - Ford Powerstroke Diesel Forum
post #1 of 27 Old 03-19-2014, 12:53 PM Thread Starter
I'm posting this here instead of under the transmission heading because I need help quick!! I have a 2002 F350 single rear wheel 7.3 ECSB with 145K. I just bought the truck not too long ago. There is a receipt for a new (used) transmission put in at 135K. The problem I'm having is that when I try to reverse up the slightest hill it will have almost no power at all. The truck starts shaking and sometimes it will slowly reverse other times it won't. The engine isnt bogging down at all. The engine is at normal rpms, but it just won't go anywhere. If I put the truck in 4x4 with hubs locked it still wont reverse up a hill. If I put truck in 4x4 Low it will reverse up any hill no problem. I have manual 4x4 lever. The truck has no problem reversing down a hill or on flat ground, no shaking or anything. Only when reversing up the slightest hill will it have a problem. Forgot to mention, it is an Automatic tranny. Any ideas??? - Mike
dobronos is offline
post #2 of 27 Old 03-19-2014, 03:46 PM Thread Starter
bump !!! i need some help guys!!
dobronos is offline
post #3 of 27 Old 03-19-2014, 07:47 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Time for a rebuild
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 27 Old 03-19-2014, 10:53 PM
Quoted: 780 Post(s)
Yep. Rebuild time. Clutches are not far from being toast. OP, when you do a rebuild or whatever you decide to do, get yourself a trans cooler for a 6.0l and drop it in.
Corey@CNCFAB is online now
post #5 of 27 Old 03-19-2014, 11:45 PM
Rodslinger's B1TCH
A shift kit would be a "bandaid" fix that won't cost much.
I had a transmission start slipping bad between shifts and reverse with a pan full of clutch material. I put in a b&m shift kit and drove it another 150,000 km until the torque converter started letting go.
Any kind of transmission mod that raises line pressure will help. Reverse is the first to go due to the higher pressure required.
Every transmission shop is going to tell you a shift kit is hopeless and you have no choice but to rebuild it... and they are the experts.
steve604 is offline
post #6 of 27 Old 03-20-2014, 12:01 AM
Googs's Avatar
Check transmission fluid ? If not that sound like you clutch packs are toast.
Googs is offline
post #7 of 27 Old 03-20-2014, 08:12 AM Thread Starter
Talked to a local transmission shop that works on super duties. He said something about the valve body being clogged up and not seating correctly? Said that he thinks that is most likely the problem. He said if the truck has no problem driving in forward gears there is no need for a rebuild. He thinks that he can pull the valve body clean it up replace fluid and there should be a problem. He said that you don't have to pull the trans to clean up the valve body? How hard is it to do? I have next week off and not sure if its something I can do.. Any ideas??
dobronos is offline
post #8 of 27 Old 03-20-2014, 08:39 AM
timmyboy76's Avatar
John Wood 4R100 Valve Body - Riffraff Diesel Performance
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 27 Old 03-20-2014, 09:14 AM
Quoted: 780 Post(s)
Lol. He definitely does not work on SD's much.
Valvebody is very easy to pull. Probably a 2 hr job total by the time you actually start draining the pan until you top it back off.
BTS has a PDF file on their site in order to do this. BTW your clutches are about done. You'll know for sure as soon as you drop the pan when you see about a 1/8-1/4" thick sludge laying on the bottom.
post #10 of 27 Old 03-20-2014, 10:00 AM Thread Starter
Looks like I can install accumulator valve body myself.. will this fix my problem? is the accumulator valve body the one that controls reverse or is it the main valve body or Lower valve??
dobronos is offline
