New IPR with reman hpop and other ??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-14-2014, 09:21 PM Thread Starter
Hello, working on a 03 7.3. I am replacing the hpop with a reman.. should I install a new IPR? The store i bought it from said i should, but per the info on the reman hpop it says not to? also any tips? should the pump be primed? or it it bolt it up then fire it up?
Dakota_Don is offline
post #2 of 4 Old 03-17-2014, 02:18 PM
duck fan's Avatar
You don't absolutely have to. It won't hurt anything to do so either. You could also re-oring the old one. There isn't a need to prime the new pump but it will take some cranking to build oil pressure back up. Best to make sure the batteries have a full charge.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 4 Old 03-17-2014, 05:36 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
Pull the allen head plug on top and dump some oil in there until it overflows.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 4 Old 03-17-2014, 07:48 PM
Whatever helps you sleep at night. Personally, I don't screw around with used ipr's on new pumps. If you have the cash flow then buy a new one.
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
