Abs and airbag lights, no blinkers, no cruise control, no speedometer, no odometer, a - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-14-2014, 10:13 PM Thread Starter
01PowestrokeDSL's Avatar
I have been having these problems intermittently when the truck starts, but they usually go away after a few minutes. Initially I was thinking the batteries could be bad, or the alternator. Then was thinkin the speed sensor or PCM. I looked on the forum and there's a lot pointing to the clock spring, but my horn is working...
Any thoughts would be appreciated... I haven't seen a clear resolution posted on the site, mainly just a lot of questions. I will be taking the batteries and alternator out for testing tomorrow. Then I'll pull the speed sensor to see if there may be shavings on it. I will post what I find...
01 F250 XLT
F6 DP Chip
AFE Stage II
4" Magnaflow Exhaust
10.5" Lift on 38X15.50 MT Baja Claws
01PowestrokeDSL is offline
post #2 of 11 Old 03-15-2014, 03:49 PM Thread Starter
HELP!!! Its not the ABS sensor, or the battery/charging system... Hoping that it is just a Loose connection in the PCM, but my luck is not that good! I checked some fuses, which were all good, but the interesting thing is that there was power supplied to the PCM, but no power to the airbag or abs systems that I could tell from the fuses...
Come on guys, let me see some ideas!!!
01 F250 XLT
F6 DP Chip
AFE Stage II
post #3 of 11 Old 03-15-2014, 05:00 PM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
Maybe your ignition is getting stuck in the start position instead of returning to run. After you start it make sure the key turns back a little.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 11 Old 03-16-2014, 11:07 AM Thread Starter
I will check that, I guess the switch could be going bad... Might not be making good contact.
01 F250 XLT
F6 DP Chip
AFE Stage II
post #5 of 11 Old 03-16-2014, 11:14 AM
ZMANN's Avatar
Quoted: 1474 Post(s)
the ABS /cruise /speedo seem related but the turn signals and airbag are confusing
when thrown in there also
We Miss you Ronnie
ZMANN is online now
post #6 of 11 Old 03-17-2014, 08:00 AM Thread Starter
Yeah I have to find some time to dig through some schematics and see if I can find something that they all have in common. I checked voltages on some fuses and there are a few that should have power relating to the abs, airbag, and a few other things. Them not having power makes me think it could be a relay. Maybe one that should be clicking after startup or something...
01 F250 XLT
F6 DP Chip
AFE Stage II
post #7 of 11 Old 03-17-2014, 05:46 PM Thread Starter
Looks like a relay problem... I did a little tapping under the dash and everything started working.
01 F250 XLT
F6 DP Chip
AFE Stage II
post #8 of 11 Old 10-29-2015, 07:49 PM Thread Starter
This bug is back... Anyone have any suggestions? I also noticed there is no power to the AC circuit...
Anyone have any detailed schematics for this truck?
post #9 of 11 Old 10-29-2015, 07:57 PM
Heavy_GD's Avatar
Quoted: 1438 Post(s)
Feedback Score: 3 reviews
Tap the dash again! !
Sorry Im no help.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #10 of 11 Old 10-29-2015, 08:23 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
The trucks are known to have some issues with the instrument cluster, maybe a bad ground. Water leaking around the windshield of SD trucks to the firewall causes a bunch of gremlins.
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
