Solid left turn signal, right signal is fine - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-13-2014, 02:10 PM Thread Starter
tristanlee85's Avatar
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
Out of the blue, I noticed that when my lights are on (parking or headlights) and when I signal left, it just stays solid. Signaling right and everything is fine. If the lights are off, both signals work fine.
I have replaced the flasher relay under the dash, and got a whole new turn signal switch. The problem still occurs. The bulbs appear to be fine and I don't see any bad fuses.
I also noticed that the battery light is always on now too. These two issues probably happened around the same time. However, I have been driving a lot and don't appear to be dropping voltage across the batteries. Both batteries are Duralast Gold and less than 4 months old. The alternator is about 2 years old.
Any ideas what else to check?
Tristan
1999 F-250 SD
tristanlee85 is offline
post #2 of 3 Old 03-13-2014, 03:58 PM Thread Starter
Nevermind... after tearing everything apart and replacing the above that I mentioned, it turns out the trailer wiring was toast from backing into a snow pile. After unplugging that harness, everything worked fine again (except I do still have a battery light on).
If it wasn't for the burning electrical smell and smoke coming from the plug housing, I probably would have found it after the truck burned to the ground.
Tristan
1999 F-250 SD
post #3 of 3 Old 03-13-2014, 05:08 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Lol I was just going to suggest the trailer wiring.
Mine screwed up and my right signal was staying on solid, but my left was flashing the third brake light too. I was so confused
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
