Battery light issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-04-2014, 10:46 AM Thread Starter
Battery light issue
This seems backwards to me, but my battery light comes during excelleration. Then turns off while coasting.
I replaced the alternator in sept. and both batteries in January. And this past weekend I replaced the steering gear box.
I have driven the truck for two days since completing the gear box swap. And didn't notice the idiot light going on and off.
The battery voltage gauge looks steady. And my lights seam ok.
I'm stumped.
Any ideas?
gr8outdoorzman is offline
post #2 of 8 Old 03-04-2014, 11:58 AM
Heavy_GD's Avatar
Quoted: 1429 Post(s)
Feedback Score: 3 reviews
just a long shot to bump this... hows the tensioner? Is the belt getting loose when you rev it up?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #3 of 8 Old 03-04-2014, 03:55 PM Thread Starter
I should be able to hear the squeal?
post #4 of 8 Old 03-04-2014, 07:16 PM
Vannnce's Avatar
Quoted: 13 Post(s)
coud be sending too much voltage? my moms car had a similair problem, under acceleration it would put out like 17-18 volts and trigger a battery light
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
The Following User Says Thank You to Vannnce For This Useful Post:
Heavy_GD (03-04-2014)
post #5 of 8 Old 03-04-2014, 07:54 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Intermittent battery lights usually indicate bad voltage regulators.
Unfortunately, the voltage regulator is part of the alternator...
Who's alternator did you get?
If it's like AutoZone or O'rilleys, that's your problem right there.
Their alternators are crap.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 8 Old 03-05-2014, 04:19 PM Thread Starter
It's oreily's.
So what your saying is I need to run a ton of gadgets. To draw the voltage down. Lol
Oreily's should be able to swap it right out? Do u think my batteries r going to be negatively affected?
post #7 of 8 Old 03-06-2014, 08:27 PM Thread Starter
Thanks for the advice. It was the alternator voltage regulator.
post #8 of 8 Old 03-06-2014, 08:30 PM
jake_duet's Avatar
O'Reilly alternators are ****. On my 3rd one in a year, but they come with a lifetime warranty so everytime i drop one, I walk in with it and they just go grab one off the shelf and give it to me without testing it cause they know me by name lol
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
