low boost high egts too much fuel help please - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2014, 06:54 PM Thread Starter
i think i posted this in the wrong spot earlier
Okay I have a 7.3 psd in a 00 ex mods are as follows, 38r ww2, farmers single shot 165/100's, t500, swamps module, 4-5" exhaust, ebpv delete, hydra custom burnt chip, intake, snow perf stg 3 water meth, i think thats it i cant remember for sure. Heres the problem yesterday I was on it hard all was working well then boost just plummeted I am making 13lbs at redline and bellowing black.
Ive checked the following map, turbo, pressurized the charge side no leaks, wastegate isn't stuck open, everything seems to be in order i just have no boost.
Any help would be great thank you!!!
slc4me is offline
post #2 of 5 Old 03-03-2014, 08:30 PM
duck fan's Avatar
When you say you pressurized the charge side, what exactly was your procedure?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 5 Old 03-03-2014, 09:13 PM Thread Starter
not sure if it was the right way but i capped the inlet side of the turbo pulled the map sensor line off and put an air charge in through that inlet and checked for leaking air
slc4me is offline
post #4 of 5 Old 03-03-2014, 11:42 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
sounds like you blew off or blew up an intercooler boot.
no obvious signs of exhaust leaks on the firewall?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 5 Old 03-04-2014, 01:37 PM
duck fan's Avatar
You really want to make something more like this and attach it to the turbo inlet.
All of your symptoms really do point to a boost leak somewhere.
duck fan is offline
