ABS light needs turned off - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2014, 05:20 PM Thread Starter
pudil45's Avatar
Send a message via MSN to pudil45
I ripped my abs wire when I took out my front axle, now I need it off so it looks better when I trade. Friend said take the bulb out. Is that the easiest?
Sent from AutoGuide.com App
2001 F 350 DRW
7.3 Powerstroke
4 inch downpipe to 5 inch mitre cut stacks
Southbend Dynamax clutch
DP Tuner
2006 F-450 6.0
Bone stock
Whelen Justice Wecan
Aluminum 11' bed with folding sides
pudil45 is offline
post #2 of 5 Old 03-03-2014, 05:35 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
No sense in trying to cheat the dealership or next owner. Why not get one from a junkyard and replace it? It shouldn't be that expensive or difficult. Certainly easier than taking the bulb out, and more respectable too. How annoyed would you be if you were having abs problems with a truck you bought used, only to find out the previous owner removed the bulb from a warning light that was put there by the manufacturer to alert you to such issues? I'd be PO'd. Do the right thing and fix it.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #3 of 5 Old 03-03-2014, 06:33 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 411 Post(s)
Or even worse.... Wheel locks up and you or the person that buys it... Crashes.
@loxdce
LoxDiesel is offline
post #4 of 5 Old 03-03-2014, 11:48 PM
Rodslinger's B1TCH
i was going to pull the bulb for my abs light but it turned out to not be a bulb in my cluster. i was going to de-solder the LED but i figured it was probably going to be one of those things that wouldn't let the truck run.
i wasn't going to do it to trade it in, i was just sick of looking at the light in the dash.
steve604 is offline
post #5 of 5 Old 03-03-2014, 11:49 PM
Rodslinger's B1TCH
and i bet that the trade-in value is going to be the same with the abs light on or off.
steve604 is offline
