White Smoke & Knock - Picture! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-28-2014, 08:30 PM Thread Starter
lookin4myPSD's Avatar
Start up my truck this morning...and the picture is what I see. I hear a loud tick, almost a cracking noise that seems to be synchronous with the RPMs. The smoke and the knock both go away after idling for a few minutes. This has just started within the past couple days.
I'm thinking it'll be glow plugs, GPR, or a bad injector. I'm going to ohm out the UVCHs, start using Rev-X, start using Stanadyne fuel additive, and do some AE sleuthing.
Any opinions? I will return to this thread with results.
Name:	White Smoke.jpg
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #2 of 6 Old 03-01-2014, 02:40 AM
Colin7.3's Avatar
My guess is a sticky injector when super cold
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 6 Old 03-01-2014, 11:03 AM Thread Starter
Thinking so. Thanks man, I need to do some tests
Early 99 F250 ECLB,
post #4 of 6 Old 03-01-2014, 03:03 PM
Colin7.3's Avatar
seems like the injector is stuck open in the morning. possible solenoid on top or just the poppet valve is screwed up
Colin7.3 is offline
post #5 of 6 Old 03-09-2014, 06:08 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 371 Post(s)
You didn't get that 6.0 yet?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #6 of 6 Old 03-09-2014, 06:31 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
**** you buy one of those then you will really be having problems LOL hahaha
6.GERNADE!
JK
2000-7.3L is offline
