Bad Fuel Mileage - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-27-2014, 10:16 AM Thread Starter
RaisenCain's Avatar
Bad Fuel Mileage
I have recently been getting really bad MPG. I run a 75HP tune and usually stay out of it hard. Truck has intake and exhaust along with chip and gauges. I have been reading about the EBPS being a culprit?
02 Crew Cab. TS Chip. DIY 6637. 4" Straight pipe. Triple gauge pillar. Boost fooler. Regulated return & lift pump on the way
RaisenCain is offline
post #2 of 6 Old 02-27-2014, 10:33 AM
It could be, I replace the sensor and the tube on my 99 (tube was plugged solid and cracked) and it seemed to help went from 16.5 to 19.8-21 depending on how many warm-ups.
mashthegas is offline
post #3 of 6 Old 02-27-2014, 10:43 AM Thread Starter
RaisenCain's Avatar
well thats a big jump! Around town it seems to be about 14-16 and highway the overhead says 20ish.
post #4 of 6 Old 02-27-2014, 11:09 AM
Not sure what I get around town but I get around 13-14 towing depending on load.
post #5 of 6 Old 02-27-2014, 06:03 PM Thread Starter
RaisenCain's Avatar
Ya I'm unloaded so I gotta look into this
post #6 of 6 Old 02-28-2014, 11:21 AM
By the way Mine is hand calculated, and when fueling I fill slow so that I can get it full to the neck of fill tube so that I know I am filling to the same point each time. The way diesel foams, if you don't you don't get accurate readings.
