Need 7.3l help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-22-2014, 05:57 PM Thread Starter
Need 7.3l help
Ok need some help while changing my injectors I'm trying to clear the cylinders I sucked the cylinders out with a seringe and turned the motor by hand so after that was done I bumped to over with the key and I'm still getting a bunch of fuel coming out. Can somebody tell me where the fuel is coming from? No injectors in and the injector harness is out and I will say I'm doing one side at a time and the driver side is still hooked up
Jmj32988 is offline
post #2 of 5 Old 02-22-2014, 06:02 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Did you pull the fuse for the fuel pump?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 5 Old 02-22-2014, 08:05 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 326 Post(s)
Change out the ones you need to. Remove the glow plugs from the cylinders you changed. Set the valve cover on it and put a couple bolts in it. Turn over a few times until you only hear air. Cylinders emptied
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 5 Old 02-22-2014, 08:22 PM Thread Starter
No I didn't pull the fuse and I was trying to avoid the mess , that's why I pumped the cylinder
Jmj32988 is offline
post #5 of 5 Old 02-22-2014, 08:36 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
When you turn the key on without the injectors in. the fuel pump turns on and starts pushing fuel out threw the heads where the injectors where. If you don't want to pull the glow plugs you will have to pull the fuse. I would check your oil to make sure you didn't pump and fuel in to the crank case. I would do what he said ^^^^^
01 f-250, Standard
