Stalling problem
Hey guys, ive been having nothing but issues with this truck so far, Truck was idleing like crap and getting bad MPG, tracked it down to a ICP, replaced it and ran great......for a day.
Then i was beating on it a lil and 5min later it died, wouldnt re-start, had a lil less than 1/8th tank. i took off fuel cap bowl was low and pump was pumping only pumping bubbles, added more fuel and it started but is was running rough. If i hold the throttle at 1500rpm its surges a lil. Then yesterday i got back from a road trip, got off highway and it stalls, starts right back up and stalls ant next light, does it every time im driving and i get off the throttle. On the highway it was sluggish and sounded like waste gate was open a lot And is still only getting 10mpg even on highway PLZ help can afford this anymore Its a 2000 f350 7.3 4x4, Dp_tuner, DIY intake, muffler delete. THANKS |
psd
bad fuel.crap in tank and pick up tube may be clogged?change cps,and if you have a chip on it take it out and put a scanner on it to see what kind of codes its got.
New cps from autozone. It was running like crap before i filled up and has been getting worse, and i only buy my fuel from one place and nobody else is having this issue. chip is coming off tomorrow. along with a pressure test.
Whats the fuel pressure supposed to be on this truck? |
okay so i found a fuel leak around the cap, fixed it and had ford look at it again, they found a 1211 code but said it was nothing and was caused by my dp_tuner. truck seems to be running better but mpg is still down. any ideas
I just replaced ICP 5 days ago. 2000 7.3, DP_tuner, Diy intake, and muffler delete |
yep still runs like crap and stalls. it gets worse by the day, takes longer for it to start too
FUel pump?
