turbo pipe with foil on it keeps blowing off!!!! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-20-2014, 10:34 AM Thread Starter
That pipe that goes from intercooler to the turbo keeps blowing off!! Driving me insane. I had to take it off along with the airbox and battery to fix the hydro hose from the hydro boost to power steering, and now it keeps piping off! Now it blew off next to the intercooler so I'ma have to take all that stuff out to get it back on. Any advice on making it stay on?? Is it bad that it pops off?
7.3L_tyler is offline
post #2 of 12 Old 02-20-2014, 12:16 PM
duck fan's Avatar
Clean the ends of the pipe real well along with the boots. Spray the pipe ends with hairspray and reinstall.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 12 Old 02-20-2014, 01:03 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Did you clean off all the oil from the CCV?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 12 Old 02-20-2014, 04:50 PM Thread Starter
I wiped it off and put it back on tonight. If it blows off again I'ma get rubber glue or somthing. Maybe weld dam thing lol. Hopefully I'll make it to work. Amy ideas on how to keep the psi down driving to work ?
post #5 of 12 Old 02-20-2014, 05:09 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You just need to clean it properly and tighten the clamps enough.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 12 Old 02-20-2014, 05:20 PM
Rodslinger's B1TCH
maybe the clamps are stripped? if i was you, i'd probably get some new clamps.
if you use glue on them or you'll be wishing you hand't done that later on.
steve604 is offline
post #7 of 12 Old 02-20-2014, 05:50 PM Thread Starter
What size clamps will I need and would local stores sell them?
post #8 of 12 Old 02-20-2014, 05:56 PM
Rodslinger's B1TCH
i'm not sure. it should probably be a spring loaded clamp specifically for intercooler piping.
maybe switch the clamps between the two sides of the motor to see if that's actually the problem.
steve604 is offline
post #9 of 12 Old 02-20-2014, 06:18 PM Thread Starter
I had to hold the clamp with channel locks and turn the ratchet so the whole thing wouldn't turn. Could it come loose like that
post #10 of 12 Old 02-21-2014, 09:59 AM
duck fan's Avatar
Local stores might have an equivalent but I have found the quality varies wildly. I got replacement clamps from Riffraff last year. But then you'll have to wait for shipping. Stainless Steel T-Bolt Boot Clamps - Riffraff Diesel Performance
duck fan is offline
