Oil change question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-18-2014, 05:20 PM Thread Starter
Reedytlr's Avatar
Oil change question
Hey guys, I'm still pretty new to the diesel world. And I changed the oil in my 2001 7.3 this evening. I drained the oil, replaced filter, and filled the engine back up with oil. I started it up and let it run for a few minutes then shut it off and checked it. It was showing about 3 quarts low. I read everywhere and they said they took 15 quarts and that's what I put in it. So I was wondering why it was reading low.
Now here's the kicker. The first thing I noticed when I got this truck was that the handle for the dipstick was missing. It had a few passes of black tape wrapped around it to act as a stop. Could it be that the previous own had somehow broke the dipstick and just fixed it shorter? And should I worry about running it until I get a new dipstick ordered if that's the case? Thanks for any help!
Reedytlr is offline
post #2 of 7 Old 02-18-2014, 05:27 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Get a new dipstick. 15-16 qts is all it takes
dhanna6powerstroke is offline
post #3 of 7 Old 02-18-2014, 05:47 PM Thread Starter
Reedytlr's Avatar
Alrighty, that's kinda what I was thinking too. But I was just wondering. Are you supposed to fill the filter and then put around 15 quarts in? Because I didn't fill the filter. I just oiled the ring and put it on the truck, then added 15 quarts
Reedytlr is offline
post #4 of 7 Old 02-18-2014, 05:49 PM
Mod Newbie
Quoted: 20 Post(s)
When I had my 95, I filled the filter and then filled the engine but it only took 15.5 qts total every time.
post #5 of 7 Old 02-18-2014, 05:51 PM Thread Starter
Reedytlr's Avatar
Alrighty, I appreciate the info. I'll just try to order a dip stick tomorrow. I'm gonna assume it's probably a dealer item
Reedytlr is offline
post #6 of 7 Old 02-18-2014, 05:52 PM
Mod Newbie
Quoted: 20 Post(s)
Yeah. Usually they aren't too expensive.
post #7 of 7 Old 02-18-2014, 06:08 PM Thread Starter
Reedytlr's Avatar
Well I'll try to find one in the morning.
After thinking about it, it was reading low on oil before I changed it and I got right around 15 quarts out of it after I calculated what I spilled on the ground and everything, lol
Reedytlr is offline
