Dash loosing power? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By AzPatMan
post #1 of 4 Old 02-17-2014, 07:20 AM Thread Starter
Premium Starfish Member
AzPatMan's Avatar
Quoted: 35 Post(s)
Dash loosing power?
I figured this would be the best area to ask this.
My `03 EX, (mfg date OCT of 2002) just started doing something random and weird.
One day about 2 weeks ago - driving home and the factory dash gauges just shut off, along with the radio. It did this 3 times. But had not done this again until this morning.
Then - I'm sitting at a stop light, and they just cut out again.
They came back on about three seconds after I started moving.
But all the time this happens - no issues with the motor running, so I know it's not my Ts Chip. Engine Idle and drivability are still fine.
Things to note - Batteries are only 6months old, and Alternator (brand new, not reman'd) is only 2 months.
Where and what should I be looking for to trace this down?
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #2 of 4 Old 02-17-2014, 08:13 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Have you ever looked at the OD wires under the column for chafing? It's a common problem that can be associated with the power to the cluster and, something you might check in any case
Here's a good how-2 -> https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
AzPatMan (02-17-2014)
post #3 of 4 Old 02-17-2014, 09:48 AM Thread Starter
AzPatMan's Avatar
Quoted: 35 Post(s)
Will definitely check that out - Thank you!
AzPatMan is offline
post #4 of 4 Old 02-26-2014, 07:00 AM Thread Starter
AzPatMan's Avatar
Quoted: 35 Post(s)
Well, found out what the problem was - and I guess it's something to add to the list!
Had to swap out my "NEW" alternator last night in 7* and snowing...
Diode/internal regulator failed, and was charging at just under 15v - and spiking higher.
Needless to say my PCM and Dash Gauges were not happy about it...
Got the new one on now, charging properly at 14.1v
dannanw likes this.
AzPatMan is offline
