Early 99 Coolant in oil, 390k miles, doesn't run. Where to start? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-15-2014, 06:39 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
Question Early 99 Coolant in oil, 390k miles, doesn't run. Where to start?
There is a good chance I may be picking up an early 99 6 speed for cheap in the near future. 389k miles. In the description it says "wont start due to a sensor that went bad from coolant". I talked to him and he said it was spitting and sputtering for a few days then shut off and would not start back up. He thinks its a head gasket and not an oil cooler. Unfortunately it is a high mileage truck that has a tuner. I know how to work on these trucks, so im not too hesitant to take it. Any suggestions??
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 10 Old 02-15-2014, 10:59 PM
Injector sleeves.
riley1131 is offline
post #3 of 10 Old 02-16-2014, 12:04 AM Thread Starter
Quoted: 2 Post(s)
I wonder how many hours a shop would charge if I pulled the heads and gave them the heads, had them checked, decked, and new cups put in. But wouldn't bad injector cups cause fuel in oil, rather than coolant in oil?
post #4 of 10 Old 02-16-2014, 12:52 AM
Rodslinger's B1TCH
i don't think injector sleeves will let coolant into the oil. you'll get fuel in the coolant and you could get oil in the coolant....
expect the worst. he said it sputtered for a few days and then shut off. he's not going to tell you that he severely overheated it or that he let if hydrolock and broke/bent a connecting rod.
make sure you get it cheap enough that you could get your money back parting it out. a 4wd 6spd is worth some good money and there is money in all of the parts needed for someone to do a 4wd conversion on their truck. it looks like it would probably have a manual transfer case too.
that truck in running condition around here would be about $3,000 around here.... i would say $1500 or less would be reasonable for that one.
steve604 is offline
post #5 of 10 Old 02-16-2014, 09:24 AM
I would swap a good mota and some 2wd front end parts for the 4wd stuff to convert.
post #6 of 10 Old 02-16-2014, 09:40 AM
Why would he want to convert from a 4x4 to 2wd
cory99 is offline
post #7 of 10 Old 02-16-2014, 09:41 AM
For a good mota.
post #8 of 10 Old 02-16-2014, 09:54 AM
So you are offering to swap him a good motor and 2wd stuff for his 4wd components?
cory99 is offline
post #9 of 10 Old 02-16-2014, 09:56 AM
Yea would have to work out the details it's a lot of stuff I would have to do some figuring would take sonevtime of he's interested
post #10 of 10 Old 02-16-2014, 09:57 AM
I've got 2 good motas
