Valve Cover Gasket = Injector trouble??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-29-2008, 01:56 PM Thread Starter
DieselGod's Avatar
Send a message via Skype™ to DieselGod
Greetings!
I have a 2000 F-350 Lariat Dually 4x4 7.3 with a cold start miss. It only does it for 5-10 minutes at warm up idle in the AM then cleans up and runs perfect all day no matter how many starts and stops I make. It sounds like 1 cylinder and is fairly suttle but obvious. I run Amsoil 15/40 HD diesel marine oil which I found out has the anti foaming properties that Ford requires and is aproved by ford (it was doing it on dino oil too). I was ready to get an injector replaced and a guy told me that the 7.3 valve cover gasket is actually a wiring harness for the injectors as well, and this could be the problem (heat during warm up causes expansion and the bad wire makes contact again). Does this make sense to anyone? I'm a recent Ford conversion from many years of Cummins, so I don't know a ton about the Navistar engines. I thought when a 7.3 injector failed it failed, so I was kinda hoping this guy might be right about the valve cover gasket...thoughts?
DieselGod is offline
post #2 of 6 Old 10-29-2008, 02:14 PM
cchase's Avatar
It is possible. I would take the covers off and inspect the wires, and the plug, alot of cases the plug can come lose.
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 6 Old 10-29-2008, 02:24 PM
usually when a harness is involved it will throw a check engine light i would pull codes and do a injector buzz test then a cont. test and see what happens with that .
EARLY 99 POWERSTROKE:wicked wheel turbo,banks 6gun tuner,diy intake,4" straight pipe,2003 pcm,08 mirrors,08 tailgate,03 headlights,tru-cool max tranny cooler,203 degree thermostat,3 guage pod with tranny,egt and boost,leveling kit,285/75/16.
badazzstroker is offline
post #4 of 6 Old 01-07-2009, 11:09 AM
payne5757's Avatar
So was the problem diagnosed?
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
post #5 of 6 Old 01-09-2009, 10:35 AM Thread Starter
DieselGod's Avatar
Unhappy It just gets better!
No, the harness and valve cover gasket tested ok, there are no DTC's. It still has a miss for about 5-10 minutes in warm up in the AM, so I'm thinking it's the actual injector. I'll have to try and find it with the Raytec gun, but I have a bigger problem right now. I lost over drive the day before yesterday and the Dealer and National transmission both came to the conclusion that the "electronic" section of the OD failed and that means yank er out and rip er down...soooo, I'm going to get a rebuilt from BD in Abotsford BC that's all wizzy so I don't have to worry about trans problems again. This tranny only has about 5000 KM (3000 mi.) on it but the shop that did it is no longer in business. However I have to save up a while, the trans and converter are $5100 plus tax and freight...plus 600.00 R&R at a local shop. Going to have to live on Kraft Dinner for a while!
2000 F-350 Lariat Dually 7.3 PSD
Custom built tranny, B&W +3 qt pan,BD cooler w fan
Custom painted 1 off 430 litre slip tank
Custom built electric re-fuel on the fly system (Me)
TDS stock rate Injectors
TS chip by Tyrant Diesel (nice tunes Cale!)
Banks Technicooler
Snow Stage 2 meth/water injection
BD Thruster II turbo(non-California)
4" turbo Back straight pipe Exhaust w 6"MBRP tip
AFE Stage 2 Intake & Zoodad
BD Exhaust Brake
AMSOIL bypass filter
Coolant filter (me)
post #6 of 6 Old 01-09-2009, 10:56 AM
szyd's Avatar
You should start a new thread about tranny options or search some tranny threads. There are some highly recamended trannys avalible in that price range. If you are gonna spend 5Gs make sure you are getting the best for youre money.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
