Speedometer Failure - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-14-2014, 08:56 AM Thread Starter
StrokinAlaska's Avatar
Speedometer Failure
I have a 99 f350, and lately my speedo will stop functioning until I get to a light and and come to a full stop. Then she kicks back in, or if I put her in park she will resume functions. Also, I noticed my Overdrive button will flash Off as this happens. My shifting is rough while this is happening so I'm pretty easy till I can get to the next light. Now this morning the Overdrive light just flashes no matter what. Any ideas ? I've heard a sensor above the rear axle is I remember right. Any help would be much appreciated!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #2 of 13 Old 02-14-2014, 05:08 PM
Yep, I would change that speed sensor on the rear axle.
99' Powerstroke is offline
post #3 of 13 Old 02-14-2014, 05:12 PM
ZMANN's Avatar
Quoted: 1776 Post(s)
the differential mounted sender is called a "VSS" vehicle speed sensor
you can try to clean it before you buy a new one and check the connection ans wire for chafing
We Miss you Ronnie
ZMANN is offline
post #4 of 13 Old 02-14-2014, 05:21 PM Thread Starter
Gonna check it right now. Thanks I'll let you know what I find!
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #5 of 13 Old 02-15-2014, 06:53 PM Thread Starter
So I replaced the vss. Still having the same issue, not sure what else to do except a computer reset. Took a my Snap on versus to it and only code I pulled was trans temp sensor high . any suggestions.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #6 of 13 Old 02-16-2014, 07:16 PM
some 4r100's have a speed sensor on the top side of the case to measure speed for pto option
yooper906 is offline
post #7 of 13 Old 02-17-2014, 10:14 AM Thread Starter
Is that different from the vss above the rear diff.?
I don't loose speedo anymore and i don't shift rough. smooth shifting and on time. But the OD just flashes now. Checked my battery grounds and the vss wiring all checks out good.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #8 of 13 Old 02-17-2014, 08:15 PM
the sensor on the top side of the trans case at the back is the output shaft speed sensor(oss), the one on top front is the turbine speed sensor(tss). They both send input signals to the pcm for speed and shifting, they are also both the same part number if you dont have a pto case, the pto case uses a shorter tss. The trans temp sensor is built into the selenoid pack. If you have a trans temp guage that has a probe in the trans, compare that to the reading the pcm gets as shown on your scanner. Should be very close to the same. If the pcm is getting a false temp reading from the selenoid pack all the time that would b your code.
post #9 of 13 Old 02-17-2014, 09:28 PM Thread Starter
I'll check it tomorrow at work.
I drove to Soldotna today at 10am, worked till 630pm and drove back got back at 9pm. 279 miles round trip. No issues with tranny yet. Of flashed the whole time. I didn't want to drive that distance on it but work is work :/
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #10 of 13 Old 02-17-2014, 09:33 PM
if you clear the code does it come back right away or do u have to drive a bit
