Need help diagnosing issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-12-2014, 07:16 PM Thread Starter
PowerStatement's Avatar
Installed 238/100 FFD injectors, a T500 HPOP, and a Sinister RR system. Everything went well, but did not change IPR or O-rings. Truck idled fine at first, so buttoned everything up. Ran it a while trying to get air out of the system. It idled like crap and still does. Only code was EBPS. cleaned sensor and codes went away. Checked ICP sensor and had oil in the connector and exposed wires, so replaced both. Now CEL on and get P1280,1210,1211 codes. Clear codes and truck dies. With CEL on Icp is 724psi and 17% duty cycle and 4.64 volts. With CEL off, ICP at 3719psi 9.37% duty cycle and 4.61volts. Any ideas?
2001 Limited Excursion
4" Level Kit w/ 315/12.50/16 KM2'S
Isspro Performax Guages W under dash pod
38R
FFD 238/100's
T500 HPOP
Sinister RR
Foil delete
Dp F-6 w/ 9 tunes including stock
4" turbo back exhaust.........still w/ muffler
5" tip
S&B updated intake......
HP Xover
6-Red LED's in cab
Edge Evolution for code reader
Prodigy brake controller
Jvc CD with amp and 10" Extant sub
Thanks for helpin since you know more than I!!
God Bless
PowerStatement is offline
post #2 of 3 Old 02-12-2014, 07:56 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Ipr?
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 3 Old 02-12-2014, 08:04 PM Thread Starter
???? I figured someone else might know more than me
38R
FFD 238/100's
T500 HPOP
Sinister RR
Foil delete
5" tip
HP Xover
6-Red LED's in cab
God Bless
