Fuel gauge goes up while driving - Ford Powerstroke Diesel Forum
Old 10-27-2008, 03:43 PM
My fuel gauge goes up from where ever it is to full while I am driving... I should have like 3/4 of a tank and it climbs to past full while I am driving?
Old 10-27-2008, 03:44 PM
duct tape & zip ties
Your fuel gauge sending unit is most likely the cause.
Old 10-27-2008, 03:45 PM
do i have to drop the tank to get to that guy?
Old 10-27-2008, 03:48 PM
Yes you do only takes about 30 minutes to drop the tank and get the sending unit out. Be advised the sending unit new from the dealer is like 350 dollars.
you should check to see if the fuel level sending unit is reading wrong. that is what is wrong with mine it will go level on my obs. but sounds more like fuel level sending unit to my and not a cluster. good luck man
Old 10-27-2008, 03:49 PM
Sorry let me compose myself..
HOLLY CRAP! I can live with that.
Old 10-27-2008, 03:50 PM
if the tank has 3/4 can he just lift the bed off the frame? that is what i do on all of the gm truck but i dont know about fords.
Old 10-27-2008, 03:54 PM
I would just wait for till i burn some diesel out, its not hard too. I dont like taking the the bed off, my friends never went back right
Old 10-27-2008, 03:56 PM
ya you shoul take a container with you that has diesel in it. so that way you dont have to go though that
Old 10-27-2008, 04:00 PM
Send a message via MSN to Justinlw
It's the Magic Refill MOD! I want that one!
I usually pull the bed also when I have to work on the tank. Alot easier than sliding around on your back all day.
