Low beam question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-11-2014, 09:23 AM Thread Starter
Quoted: 2 Post(s)
Low beam question
Got another wiring question in regards to my lighting. A few days ago, I cleaned the part of the PCM where my DP Tuner chip connects. I had some issues removing the PCM so I wouldn't be surprised if I hit something.
An already confusing thing... my low beams are on when it shows highs on the dash and vice versa(they are flipped). Well, for some reason, my low beams take about a minute to actually turn on now, almost as though there is a delay. If I flip it to high beams, they turn on immediately.
Any ideas what I should be looking for with this issue or why this may be happening?
Thanks!
winona78 is offline
post #2 of 2 Old 02-13-2014, 06:37 AM
RAMKILLER97's Avatar
Are you running H.I.D.s? If so your reversed high and low beam problem is the plug that connects to your stock harness. It has three prongs, push the prongs out and re arrange the order until you find the correct one. I had the same problem with mine when I installed my kit.
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
