Turbo Issue?
Little bit of a problem, my truck isn't building boost at all and I can't hear my turbo spool. Think the waste gate is stuck or compressor wheel? Can't do much about it right now, no time.. but I am a little curious about it! Also can't get over 60 mph and you can mash the pedal and you get nothing.
any more smoke than usual
yes, it'll blow a little cloud but not much because you can't really give it anything to blow anything. sitting in neutral though if you rev it a little there's a little more than usual
well, no boost + same amount of fuel as usual = lots of smoke.
somethings not hooked upppppp
I'll speak at you about this maggies |
psd
check up pipe donuts for leaks
To add to this: check the up pipes themselves. I had another bad boost leak & found I needed to fabricate new up pipes. Like hawaiian said, check the donuts, but also check & make sure the up pipes aren't moving.
