Slow Crank, won't start, Batt. good - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-10-2014, 05:41 PM Thread Starter
Will13's Avatar
2003 7.3L F250
So my batteries died in early December and I replaced them before heading off on a business trip for two months. It had been cranking slow and I wasn't sure how old the batteries were. After the replacement, it started much faster. I left town for two months and the person I charged with running it once a week failed to do so until around week 6 or 7 and it wouldn't start.
Week 8, I got back and put a charger on each battery. Only with the chargers boosted could I get it to start. I drove it about 60 miles, afraid to turn it off to put fresh diesel in it. At most lights it threatened to stall out. Once I turned it off in front of the house, it would not start again.
Yesterday, I took the batteries and exchanged them for new ones. With these in, it was cranking extremely slow and would not start. Both batteries had a normal output and were charged to 85 and 87%. I put them on a slow charge up to 100% and tried again today.
The starter sounded even worse. The temp is 18 degrees and I gave it ample time for the GPs to warm up. I tried plugging it in previously, but the element won't warm, which is another problem entirely.
I also noticed that one of the positive leads was very hot to the touch after trying to start the engine. This is leading me to believe that there may be a short in the starter.
Does anyone have advice on troubleshooting this issue to make sure it is the starter before I just replace it? I'm away all day at work, so I won't have daylight to really give it a good look until the weekend.
I searched around and couldn't find any problems quite the same as this; but if there is a thread you can reference me to I would appreciate it.
Thanks.
Will13 is offline
post #2 of 3 Old 02-10-2014, 07:01 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
battery cables and connections fall apart on these....
schluzter built his own cables and he had great luck.
also check grounds as welll.
if your still having trouble might be time for a new starter!
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
Will13 (02-10-2014)
post #3 of 3 Old 02-12-2014, 06:19 PM Thread Starter
Will13's Avatar
Yanked the starter when I got home from work around 8. Tested it and it turns out to be a short. The inside was covered in grit and the brushes were all cracked. The short seems to be a busted solenoid. Wish an autoshop was open to service trucks plowing snow, but no such luck.
Will13 is offline
