01 7.3 oil in coolant?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-10-2014, 04:04 PM Thread Starter
BuckHunter25's Avatar
Hi everyone,
just bought my first diesel and am new to this forum. I purchased a 2001 f350 with the 7.3 with 153000 on it. The previous owner said that the oil cooler o-rings were bad and needed to be replaced. Could this cause oil to get into my coolant reservoir? It looks kind of black in there. Is this very bad and a hard fix or is it simple?? Should I stop driving it until it is fixed or is it still drivable??
thanks everyone!
BuckHunter25 is offline
post #2 of 7 Old 02-10-2014, 05:59 PM
Originally Posted by BuckHunter25 View Post
Hi everyone,
thanks everyone!
Easy fix for less than $100 in parts. You should probably quit driving it as all you're doing is making a making a bigger mess to clean out of the coolant side of things.
Dan V is offline
post #3 of 7 Old 02-10-2014, 08:02 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
yes a failed cooler will do this.
you have to clean all the oil out of the block now....
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 7 Old 02-10-2014, 08:41 PM Thread Starter
Thanks for the responses guys! so do you think it is just the o-rings and gasket or should i get a whole new oil cooler? will i need to use some kind of special cleaner/chemical to flush out the oil in the coolant?
post #5 of 7 Old 02-11-2014, 05:35 AM
Just the gaskets and o-rings...the cooler itself is pretty stout. When people have diesel in their coolant they use Cascade soap...I don't know if it Cascade dishWASHER soap or what...but search that, it will give you the info you seek.
Dan V is offline
post #6 of 7 Old 02-11-2014, 07:03 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
dawn...but same diffrence
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 7 Old 02-11-2014, 07:06 AM Thread Starter
Thanks guys appreciate the help!
Tags
7.3l diesel , f350 7.3 , oil cooler , oil in coolant , oil leak
