Early 99 Knocking and shaking at idle - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-06-2014, 06:57 PM Thread Starter
Got an early 99 f350 that shakes and knocks pretty bad but only at an idle, once over idle there's little to no knock at all and same with the shaking and zero power loss whatsoever it runs super strong.
I had injectors scanned and buzzed tested and came up with nothing wrong. Tried replacing the CPS that didn't do much either. Recently it has been "running out of fuel" when it's been sitting for a day and I run it, it acts fine then I get down the road and it runs out of fuel but them cranks back up and runs fine?
Can't come up with anything, so any ideas would help! Thanks guys
Forddiesel52 is offline
post #2 of 8 Old 02-07-2014, 05:50 AM
Seth14's Avatar
Check your ipr duty cycle, could be bad....mine was, change the whole idle and throttle feel once changed.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #3 of 8 Old 02-07-2014, 02:07 PM Thread Starter
I had it scanned today and showed cps and icp so I replaced those and it runs good now doesn't shut down goin down the road anymore but still shakes and knocks the same, gunna try ipr soon will let y'all know
post #4 of 8 Old 02-10-2014, 01:48 PM
Did you check the nut on the IPR it could just be loose
cory99 is offline
post #5 of 8 Old 02-10-2014, 02:50 PM Thread Starter
Yeah it doesn't seem to be loose at all, it runs good just knocks and every morning it cranks runs fine for a few minutes then goin down the road sputters like it's out of fuel and white smokes then takes a minute to crank then runs good the rest of the day, no idea what it is!
post #6 of 8 Old 02-11-2014, 03:41 PM
Also the buzz test only test the electrical side of the injectors would need to do a cylinder contribution test to possibly pin point injector issues.
White smoke is fuel so would say your not running out of fuel. I would also try plugging it in at night to see if the problem persist. Try searching on the forums have noticed alot of threads recently on trucks that just die after running a while see what they came up with.
cory99 is offline
post #7 of 8 Old 03-04-2014, 10:20 AM
Jerry@tx's Avatar
LOW OIL, add more oil.
Jerry@tx is offline
post #8 of 8 Old 03-04-2014, 08:50 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
ya low oil could be causing some issues....
try a delphi hts101 cps, i had crappy idle with the ford cps. the delphi improved the idle.
i also replaced my ipr with no signs of it being bad and what a difference. The truck ran smoother and had way more power with a new ipr.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
