Leaking EBV - Ford Powerstroke Diesel Forum
Old 10-22-2008, 08:00 AM
CompressionIgnitionAddict
Leaking EBV
My ebv accuator is leaking, I was wondering if Ford or anybody else made o-ring kits for this problem. Im tired of chasing this darn oil leak for the past 2 months.
Old 10-22-2008, 08:07 AM
International Threat
Well the valve won't leak oil, however the pedistal will.
Verify that's what's leaking and let me know.
Old 10-22-2008, 08:08 AM
I know this video title states gutting the EBPV but it's really gutting the pedistal. I have another video that got corrupted that was about gutting the EBPV and was not able to fix it.
Gutting the Turbo Pedistal
Old 10-22-2008, 11:44 AM
Well, I just put new o-rings top and bottom yesterday, took it out today for a 30 min or so drive, and the leak is still there, its collecting on the linkage to the EBV itself. I went to my ford dealer and got an exploded view, it seems like there are 4 o-rings on it. I could be wrong. If its not the EBV accuator what could it be ? I meant in the title and first thread to put accuator not just the valve, obviously the valve itself shouldnt be leaking oil, if it was i would have bigger problems.
Old 10-22-2008, 06:16 PM
Anybody have any ideas ?
Old 10-23-2008, 09:51 AM
Yes, it can leak out of the pedistal at the actuator arm.
Is there oil in the valley? If so, check your HPOP O rings.
Old 10-23-2008, 10:56 AM
have you thought about just doing the ebv pedestal delete....if that is where it's leaking from that is.
Old 10-23-2008, 02:12 PM
Yes, there is oil in valley, one of my HPOP fittings is starting to leak, I've got the kit at home just havent had time to put it on.
I have thought about it, but Ive got my ebv hooked to a toggle switch to use it as a exhaust brake. I kinda like the fact that its a cheap way to have an exhaust brake. But at the same time if its gonna cost me 160 bucks just to get new o-rings. I was just wondering if anybody has had this problem and had an idea of part #'s or dimensions. I plan on taking it apart tonight after work, hopefully being able to match the o-rings up at a parts store.
Old 10-25-2008, 03:06 AM
i have a pedistal i just rebuilt less then a year a go..no leaks what so ever.. dieselsite sells a rebuild kit for 140 plus shipping..
http://www.dieselsite.com/index.asp?...ROD&ProdID=314
i am gutting my EBPV for a 1.00 exhaust housing and SS stage2 injectors.rather then gutting a perfect pedistal id rather get a new non EBPV pedistal..ill let mine go for 140 shipped to you...here is a pic of it..its the orange one and is still on my truck right now..be pulling it next weekend..it still looks new..i can take a new pic with it installed if you want.
