E99 with a 99.5 motor, Injector Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-05-2014, 09:06 AM Thread Starter
I just put in a late 99 motor in my E99 F350. Now I have a couple of injectors bad.
I have good AB injectors from the old motor. I also did not change the PCM, Jody at DPtuner told me that the E99 PCM will work fine with the late 99 motor.
The question is can I use 2 AB injectors with the rest of the AD injectors? I know the AB injector flow 20cc less, just need to get it running good and let the funds build back up to get the right injectors.
Thanks
Fursch is offline
post #2 of 3 Old 02-05-2014, 05:57 PM
You can run them, if your old ones ran fine might be best to change all 8 out to the ABs
cory99 is online now
post #3 of 3 Old 02-06-2014, 05:12 AM Thread Starter
Didn't think of it that way! well I put in the 2 for now and the truck runs a lot better. I'll wait until I can get the money for a set of new injectors and a chip for all the stuff I put on the truck.
Thanks for the feed back
Fursch is offline
