Braking problem - Ford Powerstroke Diesel Forum
Old 10-20-2008, 05:41 PM
Braking problem
OK on my 2002, crew cab, F250 When i press on the brake pedal it makes the whole truck chatter or rumble, its sort of hard to explain what it does. A friend said its like my ABS is on crack lol. It seems like the ABS is messed up or some thing. Any one have any idea what it could be? or a solution because it gets rather annoying when driving through town and every time you touch the brake the whole truck rumbles.
Old 10-22-2008, 01:32 PM
The Screwy HEUI
Usually if you were having a problem with your ABS, your ABS light would go on. Try scanning the ABS & see if there are any codes. It sounds to me, though, like your rotors are warped or you may need a brake job. How's your bake fluid level? Have you pulled the wheels off?
Old 10-22-2008, 01:33 PM
Send a message via AIM to SteveKran Send a message via Yahoo to SteveKran
I'm guessing the rotors are severely warped.....time for new ones.
Old 10-22-2008, 02:03 PM
Ill check the rotors and change them if they need to be.
And yea i had the wheels off not to long ago because one of my caliper pins was frozen so i just put 2 new ones in.
Old 10-22-2008, 04:42 PM
Well i changed the rotors and it still does it. Any other ideas on what could be wrong? it brakes just fine just really annoying that's why i want it fixed.
Old 10-22-2008, 05:56 PM
The Screwy HEUI
Something doesn't sound right. You don't have any problems with steering components? Tires are in good shape? Have you tried scanning for the ABS codes?
Old 10-22-2008, 07:18 PM
I changed out my rotors/pads not too long ago because they were warped. The caliper pins wern't "free sliding" like they should have been. I think that might have been the problem...
Old 10-22-2008, 09:08 PM
Nope no problems with steering, tires are brand new and are stock size. I forgot to scan it while i was out there, ill do that tomorrow and tell you what happens
The caliper pins should be fine i just put new ones in because the truck was pulling really hard to the left when i braked, i put them in about 2 weeks ago so i wouldnt think they froze up already.
