7.3 Fuel Bowl Vacuum Switch - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-03-2014, 09:58 AM Thread Starter
COBHC's Avatar
Hello all, I'm having some trouble locating a fuel leak. Fuel is pooling in the valley and dripping on the ground near the back of the engine. I have resealed the drain valve and replaced the fuel filter and cap with a new motorcraft unit, yet the problem persists. I feel there is a potential that the vacuum switch on the bowl may be leaking, and I'm looking to remove and plug it. Where is the sensor located on a 2001? I can't seem to find it.
2001 F-250 scsb 4x4 7.3 PSD w/PMR's...
6637, Diablosport Predator, 4" Magnaflow Turbo Back, '05 front end conversion w/ DIY Harley Headlights, 2.5" Rough Country Leveling Kit.
COBHC is offline
post #2 of 6 Old 02-03-2014, 10:41 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Vacuum Switch? What's That?
NoRalPh is offline
post #3 of 6 Old 02-03-2014, 10:50 AM Thread Starter
COBHC's Avatar
Also called a fuel restriction switch I believe? I know OBS trucks have em and the sensor itself is prone to leakage through the sensor. Do super duties even have them?
COBHC is offline
post #4 of 6 Old 02-03-2014, 11:55 AM
Quoted: 184 Post(s)
I don't think so....
NoRalPh is offline
post #5 of 6 Old 02-03-2014, 08:27 PM
Quoted: 14 Post(s)
Nope. Only electrical hookup on the fuel bowl is the fuel heater.
ttyR2 is offline
post #6 of 6 Old 02-04-2014, 06:33 AM
Quoted: 908 Post(s)
Could be the fuel line O-rings. Four of them on the bowl.
2- 1/4"
1- 5/16" return line
1-3/8" supply line
They go bad easily and typically are not reusable. If you get the Viton or military grade Viton, those can be possibly reused.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is offline
